Question about Dynex 32 in. LCD Flat-Panel HDTV
Playstation 3 won't hook up to my dynex tv with
  • 88 Answers
Did you check the side of the television for the AV/Compsite ports (Yellow, Red, White)? A lot of models have these connections on the side of the TV. You did not list your model number so I cannot really check for you.
Posted on Jun 15, 2011
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
Does the JVC AV-56P776 have any kind of lock out on it went thru setup it plays dvd's but not regular tv
if plays DVDs via rear connections what have you got hooked to it for regular tv reception? Hooked to the coax fitting, using antenna or cable or sat with a box or not?
Good news is if it works with DVD set is likely ok and you have some other issue----just need some more information to decide what that issue is.
May 02, 2012 | JVC Televison & Video
I put in my mw2 disk and it won't load and goes
Hello
If you took your PlayStation 3 to a friend's house and hooked it up to his HDTV with an HDMI cable, you may have been in for a surprise when you got home to your older television. If you didn't change the video output back to the regular AV cable, your system will still output video to a port you now can't use.
Connect your PlayStation 3 to your television with the composite yellow, white and red AV cables and plug the system in to the power outlet. You can also use a component cable if you own one and your TV supports it. If you already turned the system on and see no video, turn it back off with the power button.
Press and hold the power button until you hear two beeps after about five seconds. The system will reset to SD output on the AV cable and proceed to boot normally.
Press the "PS" button on a controller to turn it on and log in to your user account. The reset process removes all video settings, so you will need to choose your options again.
Select the "Settings" menu and pick "Display Settings" and then "Video Output Settings."
Proceed through the settings to select TV type and resolution. If using the composite AV cable included with the system, settings should be correct automatically after resetting, but verify them to be sure. If you're switching to a component cable on an HDTV, you will have to reselect the compatible HD resolutions of your television.
Save the settings and continue using your system as normal.
Sep 26, 2011 | Sony Video Game Consoles & Games
I am trying to connect my NES to my 40" Dynex HD TV through the AV cables and the tv says no signal but i unhooked the HDMI cable and tried the AV cables for my xbox and the xbox worked fine. How can...
  • Well the XBox has it's own AV cable pack it uses. The AV cords you are using for the NES are a separate set that are apparently bad. So to play using the AV cords you just need to pick up a new $2usd pair or see if you have a pair laying around the house.
  • You do have a coak input on the back of your TV so if you have an old coax cord laying around the house you can use the RF bonx that cam with the NES. Hook the coax from the TV to the "OUTPUT" side of the RF box and then run the little RF cord to the NES. Then turn the TV to channel 3 or 4 and you can play it that way.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 21, 2011 | Video Game Consoles & Games
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
Playstation 2 and 3 won't work on Sylvania 6432TE tv.
If you are using the Yellow, Red and White cables I believe you have to put your tv into AV mode. There should be a button the the remote or sometimes there is one on the tv
Mar 30, 2009 | Sony PlayStation® 3 (80GB) Console
Powers on but nothing happens
It happened to me too. When you plug in your av cables and are ready to play, follow these steps. With your PS3 off (Red light on), Press and hold the power button on your console. (Do not use the controller to turn it on.) Keep holding the button until you hear a second beep. (it takes about 2 to 3 seconds.) You will notice your screen flickers, then your PS3 will show up on the tv. All you did was reset the PS3 display settings. You can always go back to HDMI or AV cables. Have Fun.
Mar 07, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
Dynex 32 in. LCD Flat-Panel HDTV Logo
203 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
