Is the mistral mss 3.3 a reverse cylce unit? how do i turn the heater on? what symbol on remote do i use please?
relaga58
  • 158 Answers
SOURCE: mistral mss15 aircon will not operate on heat
Press mode button one at a time until sun sign appears on the display panel.
Posted on Jul 12, 2009
atocrxr
  • 135 Answers
SOURCE: Mistral mss 1.0kw unit - When switched on the
If the indoor unit blower is running and the outdoor unit fan is turning, you will need to make sure that the compressor itself is actually running and that it is not just the outdoor fan that is turning.
Get close and listen to the end of the unit were the compressor is located, also carefully feel the two copper lines, where they connect to the outdoor unit, they can be very hot - if working properly, so be careful.
There is no reset button that is easy to get to, the limits are usually auto resets, I would hazard a guess that the system is low on refrigerant and will require a HVAC tech.
But before that, make sure that the coils / fins on the outdoor unit are clean and not plugged with leaves, grass, cottonwood, ect.
You can turn power off to the unit and carefully wash the coil out with a garden hose, do not use a nozzle, as the higher water pressure can bent the fins.
As the water runs thru and drains off of the coil, watch and see if it is very dirty, rinse till the water is clean.
Restore power to the unit and try it, If it still does not work, the unit might be low on freon or the safeties might have been already damaged.
Once the unit is repaired, in the future make sure and keep the coil rinsed and free of any blockages.
Paul Gibson
Posted on Mar 30, 2010
Testimonial: "Thank you very much for your prompt reply. I was hoping there might be a quick simple "reset" elctrical problem. Looks like it had a ? refegerant leak"
technic_7117
  • 38 Answers
SOURCE: Mistral aircon MSS 2.0 Turns on
s.just change the thermistor coil
Posted on Aug 20, 2010
  • 1417 Answers
SOURCE: I have a Mistral Inverter
hello,
What this problem indicate is that the thermostat of the air condition has been gone bad.
When ever an refrigerator does such it simply mean that thermostat need to be replace by some time it could be on the time programming
note , this problem is on the thermostat you can get the (part)replacement at the below site if you which to order for it livesupport.maybenow.com
or you invite then to visit the system only if you can not carry out the solution your self
To do this fix up your on then carefully unscrew the screw on the condition
thank you and thanks for using fixya.
Posted on Sep 28, 2010
  • 320 Answers
SOURCE: Hi I have a mistral
Check if your a/c unit needs cleaning dirt's sometimes causes not to cool the air. But if your unit is clean then your compressor needs to be re-charged with freon.
Posted on Nov 12, 2010
Hi am looking for a user manual for mistral heater model no MCVPH. WAS GIVEN TO ME WITHOUT MANUAL
Google (mistral)(MCVPH)(manual) without parens OR contact Mistral directly with your request.
Jun 26, 2018 | Heating & Cooling
Mistral 5 Speed wall controller switch for a ceiling fan has failed and the fan is stuck on high speed and can't be turned off via the switch. Can it be replaced with a modern 3-speed wall switch?
controller switches are changing every day
there are available a variable speed unit that alters the sine wave so you have any speed you like
Talk with a fan shop or qualified electrician as they are easy to install and are as cheep as the others
Apr 07, 2018 | Dryers
Energy knight wall ac unit wont turn on with remote? Model mss-012B
The only thing you can do that is not going to cost you a service call is to replace the remote and hop for the best.
Sep 08, 2013 | Heating & Cooling
Hi, my daughter has just moved in to a property with a mistral mss6.5 system, with no instructions left behind on how to operate it. they replaced the batteries in the remote, but do not know how to reset...
Without being able to see the remote, there are three possible solutions which spring to mind. Firstly, contact the people from whom they bought the property, or place an inquiry through the sales agent. Ask if they have the manual, or if they can explain how the remote functions.
Another possibility is to take the remote into a local store that installs and repairs air conditioners and ask how the remote works. Presumably when she bought the house your daughter was told that the unit was in working order, so if after a sales or service assistant has shown her how to operate it, the air conditioner still won't function, she need to tell the house agent about it.
Finally, she could use the link below to the Mistral website and send them a query and also ask for a manual. I hope this helps!
http://homeappliance.manualsonline.com/ex/product/headline/m/mistral/d/air_conditioner/p/MSS6.5
Aug 21, 2011 | Heating & Cooling
Hi I have a mistral reverse cycle a/c model MSS 15 the fan works but the air coming out is not refrigerated.
Nov 12, 2010 | Heating & Cooling
I have a carrier wall heater with a remote, and I don't have the directions for the remote. I can't turn the heater on! I press the power symbol, but nothing happens.
Hi, Sally378, I may need to get any model numbers you may have for the remote or the unit to solve this. If this remote has batteries you may want to change them to see if this takes care of it. If not, send me the model numbers from both the remote and unit itself.
Sincerely,
Shastalaker7
Jan 30, 2010 | Carrier XHD183D Air Conditioner
Mistral mss15 aircon will not operate on heat setting , not sure if it is being set properly because cannot understand remote control symbols
My Mistral was working yesterday (on heat) now it won't. Just sits there as if warming up but actually blows out freezing air - on "sun" mode.
Jul 12, 2009 | Sanyo 24KS32A Cool Mini Split Air...
No air Blowing out of indoor unit
pls check remote batteries then set the remote on fan mode put on if no response check power if ok checklow voltage fuse in side the control boardif all are ok mens the indoor fan is out
Apr 29, 2009 | Heating & Cooling
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
