Question about Hotpoint Ovens
My hotpoint sy56x the grill element is not heating up. only 2 1/2 years old
5 Suggested Answers
  • 52 Answers
SOURCE: Indesit grill element not heating up
It may be the oven temperature sensor.
Posted on Mar 25, 2008
apart4u
  • 213 Answers
SOURCE: my hotpoint oven is not heating up but hobb and
If you have a HOTPOINTelectric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fanmotor inthe back of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from ourwebsite these can be tested with a electric meter.
To gain access to the HOTPOINTelement youwill have to remove the back plate from inside the oven. Once removed you willsee the fan and element,if you look closely at the element you will probably see a small hole burnt in it where ithas blown. Sometimes however there is no evidence of a fault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your HOTPOINTfan oven is getting warm buttakes a very long time to cook or is burning the food more on one side than theother, then you need to check if your oven fanmotor is working you will seethe blade turning fast if it is ok. if the element is heating but the fanmotor isnot blowing the heat into the oven then you need To replace the oven fanmotor is a little more expensive and a bit moreinvolved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your HOTPOINToven thermostat
4, A quite commonand easily overlooked answer is if your HOTPOINToven is not working at all ie:no heat and no fan then the chances are that someone has put the oven timer intoAUTO mode, simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 25, 2010
arepairman
  • 20 Answers
SOURCE: hotpoint sy36x grill element works fine but when
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Posted on Mar 14, 2010
SOURCE: Have had 4 Neff oven elements in 2 years.
As barkencoa says, cheap elements from ebay etc don't last long. I proved this myself when my Neff B1320 fan element blew. I replaced it with one for about £10 from ebay. It lasted about 11 months. Last replacement I fitted was from Currys Partmaster. So far it's ok after 6 months.
Posted on May 08, 2010
Just purchased a new grill and oven element for a hotpoint ew74 oven but forgot to draw a diagram which wire goes where on the element please help
remember the old saying a picture is worth a thousand words .try hotpoint.com perhaps they have one
Dec 22, 2014 | Hotpoint Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint uy46 style line stainless steel, 2 year old, main oven fan takes 20 to 25 mins to start then runs too slow and some times stops, but the heat element is glowing red and very hot
The symptoms you describe are an indication that the fan motor is in imminent danger of breaking down altogether.
You need to replace it as soon as possibe, otherwise you will end up with the element burning itself out, thus doubling the cost of repair.
Please rate my solution.
Thankyou.
Jan 26, 2010 | Hotpoint UY46 Style Line Stainless Steel...
The main oven is not working, no fan or heat could this be a fuse? Stopped spontaneously, top oven and grill are working perfectly, only 2 years old. thank you
This sound like the heat element for the main oven is burnt out, replace the main heating element and this should correct the problem.
Nov 14, 2009 | Ovens
Need heating element for old Hotpoint built-in oven
Midwest Appliance Parts
2601 West Diversey
Chicago, IL 60647
1-800-621-1932
- Toll Free
1-773-278-1300
- Local
Supply a wide range of hotpoint oven heating elements
Apr 11, 2009 | Ovens
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Ovens Logo
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
