Toshiba Laptop Satellite L500 screen display colour problem; black turn green and white turn pink. When the laptop is on after a while, the display go back to normal but just for a second. Then it turns back to green and pink for black and white colour again. The screen is also flickering. Anyone, please help me.
Geekman
  • 32281 Answers
SOURCE: Display has gone bad with fine vertical pink lines
Connect an external monitor to your laptop, if you get a clear image on this monitor the the video card in the laptop is OK.
The fault could be a defective inverter that supplies high voltage to the CCFL lamp or a faulty CCFL lamp. Most likely a faulty CCFL lamp.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) as reached the end of the life and all you need to do is replacing the CCFL lamp
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 06, 2009
mdsaeed67
  • 849 Answers
SOURCE: Display Problem Black turns Red
the is some loos connection in the staip comming from lcd to motherboard.
check it.
Posted on Nov 24, 2008
SOURCE: laptop screen suddenly turns white display
Toshibas have a HORRIBLE HORRIBLE HORRIBLE overheating problem. In your case, it sounds like the video card is overheating. Use compressed air in a can to blow dust out from inside your laptop. Then lift it up off your desk by propping it with something small, or buy a notebook cooler base. the problem should go away. I'm surprised you haven't experienced auto-shut-off yet.
Posted on Dec 11, 2008
Geekman
  • 32281 Answers
SOURCE: I dropped my laptop, white pixels turn pink
The CCFL lamp has been partially damaged and could fail completely any time. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
var selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 = null; function checkReviewsMarked() { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { $('btnctl00_SideColumn_ctrl_rater').disabled = ''; $('btnctl00_SideColumn_ctrl_rater').className = 'c_sub_small sub_enabled'; } } function checkAndSend(obj) { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { setRate(selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3, function() { window.location.href = window.location.href; }); } }
Posted on Jul 09, 2009
  • 82 Answers
SOURCE: laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Posted on Aug 15, 2009
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
My screen on toshiba satellite l500 went white. I connect it to the tv and it works. Tried re install drivers, made the updates, took out the battery, and nothing worked. Ideas? Urgently? Thanks.
The data connection cable between the lcd screen and the motherboard of the laptop is damaged - the laptop will have to be completely dismantled to have it replaced.
It's a big job, take your laptop to a repair shop.
Jun 23, 2011 | Toshiba Satellite L500 Series Notebook
When I turned on my laptop today the screen did not turn on. The green light is on, on the keyboard so looks like the computer is on but there is nothing on the screen. Any suggestions
try to do a power drain by removing the battery and anything connected to it..> press power button for 1minute > plug back in the charger and after few secs try to turn it on...
May 12, 2011 | Toshiba Satellite L500 Series Notebook
The display on my L675 S7048 is flickering badly. My whites turn pink, and my blues turn green. I see it when windows starts, even the Microsoft logo has tiny green dots all around it. When I connect an...
WHITE is a mixture of the three "primary" colours.
If one of the colours is not working, then WHITE turns PINK.
So, either your LCD display is malfunctioning,
or the "data" cable between the LCD and the motherboard is malfunctioning (not transmitting all 3 signals),
or the video-card embedded into the motherboard is malfunctioning (not sending all 3 signals).
This is nothing that you can fix by yourself; take your computer to a qualified technician, for trouble-shooting and repair.
Jan 19, 2011 | Toshiba Satellite L675-S7048 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Vertical lines are appearing on my toshiba laptop
first try to hook it into an external monitor if it looks good,I would have to say you have a damaged cable on your monitor.if you are comfortable taking it apart you can try to reseat the ribbon cable on the mobo.you can usually find an online manual for disassembly.
Apr 23, 2009 | Toshiba Satellite 2455-S305 Notebook
Mar 06, 2009 | Toshiba Satellite 5205-S703 Notebook
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
