Question about Fuji FinePix MX-1200 Digital Camera
I have a fuji finepix ax and both mine and my sons lens is stuck out and will not close help
  • 12 Answers
SOURCE: fuji finepix a510
Check out this link: www.digitalcamera-hq.com/digital-cameras/fuji-finepix-z1_question.html?qid=4289
After the basics, try dropping the camera on a carpeted area from about 2-3 feet. It worked for my Fuji A500 and 90% of the responders on the link. Everything on the web said it would cost ~$100 to fix. I was in the process of researching new cameras to buy and had nothing to lose by dropping it on the floor.
The error may be caused by debris in the zoom mechanism preventing it from working. Dropping the camera loosens the debris and voila!
Posted on Jul 07, 2008
  • 11967 Answers
SOURCE: Fuji FinePix A345 Digital Camera lens is stuck, I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 17, 2009
Testimonial: "Thanks a lot, this is a F**king great solution, man you should post it a tip or something it's grat "
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
  • 11967 Answers
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
Posted on Dec 28, 2009
lock123
  • 6831 Answers
SOURCE: fuji film finepix f20 zoom error. it's stuck and won't move
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
My fuji ax camera will not take pictures
Likely a lens error. This video may help you correct it without even opening the camera:
https://www.youtube.com/watch?v=AkEfnF6zVxc
Oct 12, 2014 | Fujifilm Finepix Ax500 Digital Camera -...
Lens will not close when camera is turned off
May be there is some spec of dust stuck in the lens well. You must use your vacuum cleaner to pull out the dust from around the lens housing while powering the camera on and off.
Oct 29, 2009 | Fuji FinePix S1000FD Digital Camera
Hi, MY LENS IS STUCK AND I LIVE BETWENN CANCUN AND PLAYA DEL CARMEN.i HAVE A DIGITAL FUJI FINEPIX S1000.PlEASE HELP
The Camera must have fallen down and it Can be the barrel itself has gone bad
you can take a risk and try at home twist very slowly the lens and try to get back the original position if not then you need to replace the lenns barrel.hope this helps
Sep 01, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom error in my camera.cant close the camera!
more likely lens has to be replaced .depending on model of unit.Some may not be practical to repair doe to high cost of lens replacement.
Aug 05, 2009 | Fuji FinePix F710 Digital Camera
Lens stuck in out position, screen shows zoom error. How can I fix the problem?
just take out the battery ....charge it ...and put it back....switch off and switch on the camera once....should work fine
May 15, 2009 | Fuji FinePix A345 Digital Camera
ZOOM ERROR ON FUJI FINEPIX J10
Mine did this too, and the lens cover only opened half way. I used a cotton wool bud to push the lens cover back and held it back until the lens clicked into place, turned it off and on and then it was fine
Jan 13, 2009 | Fuji FinePix 2650 Digital Camera
Lens filter ring fell off !
I have Fuji 3800 camera, the lens ring on the camera fell off. How do I get the 3 screws out of the camera and how do I fix it.
Aug 13, 2008 | Fuji FinePix 3800 Digital Camera
Camera stuck in open position.
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 09, 2008 | Fuji FinePix F610 Digital Camera
Zoom lens won't retract
help!!
mine is the exact same way
should i just buy a new cam?
Jan 03, 2008 | Fuji FinePix F20 Digital Camera
Digi camare
The lens on your camera has become stuck due to being dropped, contamination such as sand, or a malfunction within the lens. If gently manipulating the lens itself does not free it then you will need to get it professionally repaired or replace the camera. David Millier Advance Camera Repair
Feb 07, 2007 | Fuji FinePix F401 Digital Camera
Fuji FinePix MX-1200 Digital Camera Logo
1,317 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
