Question about Samsung LN-T4061F 40 in. LCD HDTV
Complete black screen on samsung 46 inches
H! I have 11 months old 46 inces LNT4661FX/XAA.
When I open the TV the screen goes complete black after couple seconds but sound is ok. This happens on all channels and even on other video sources such as DVD.
Looks like there is no picture or light on the screen.
Do I need repair?
  • pauliemsu Sep 21, 2008
    I have the same problem and I am past warrenty. I can watch it for a while then the sceen goes black. sound is fine. Now I turn it on and it is black from the start on all sources. What is wrong with it and is this something I could fix myself?
  • 2,296 Answers
Yes, you do need to get the LCD repair before the warranty expires. Call the manufacturers to find an authorized service center near you.
Good Luck.
Posted on Aug 15, 2008
2 Suggested Answers
SOURCE: Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Posted on Oct 07, 2008
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
Tip
I have a 46" Samsung LNT4661FX / XAA LCD TV. I pulled the back off and noticed 2...
For this tutorial, I will be addressing a common problem experienced by many Samsung LCD, flat panel TV owners these day... "My Samsung TV keeps clicking for 20 minutes before it comes on" or "When I press the power button on my Samsung, nothing happens" or "When I turn my Samung TV on, there are white dots on the screen" or "When I turn my Samsung TV on, there are multi-color vertical lines on the screen"... there may be more, but these are the most common I know of. The models are numerous and seem to stretch from 08' - 09'. If you are having this issue and want to fix it yourself, read on.
TOOLS: #2 Philips Screwdriver, Wire Cutters, Soldering Iron, Desolder wick (with Rosin), Rosin Core Solder, Replacement parts (will be determined after disassembly).
The first thing we need to do is unplug the TV and move it to a good work location. You will need a soft place to place the TV, perhaps on a carpeted floor or on a blanket placed over the kitchen table ;).
Remove the 4 screw for the stand (RED area) and then pull the TV off the stand and place the TV face down on you soft work surface. Remove the 4 large screws (GREEN area) and the rear cover screws (YELLOW areas). Now remove the rear cover (screw location may vary depending on your exact model, so please make sure have them all out first).
Depending on your model, you may have a metal shield covering the boards. If not, you can skim ahead...
There are 2 major boards that will be front and center inside your TV. On the left we have the SMPS... this is where we will be working. So, we need to remove the shield cover to get to it.
Now that we have the cover off, we are able to take a closer look and locate the faulty parts. Have a look at the upper right corner of the SMPS (Switch Mode Power Supply). You will see a cable going over to the main board on the right... in this area you will find the problem.
The faulty parts are capacitors. The tops are generally swollen and often have blackened material exposed or leaking from their bulging tops.
You will need to identify the electrical value of the parts and locate suitable replacement parts (try Radio Shack). The values may be 1000uF 10v, or 2200uF 10v... whatever they may, you replacement part have an identical uF value but a higher v value... ex: Original, 1000uF 10v -> Replacement, 1000uF 16v. This will help prevent this problem from reoccurring.
Once you have the replacement parts, you are all set to install them. So, unplug the connection on the SMPS and remove the screws from the board. Heat up that soldering iron and remove the capacitors. Use the Desolder wick to clean up the pads, this will allow you to insert the new capacitors with ease. Be careful, these parts have polarity. This means that they need to be installed the same way you removed them... positive to positive and negative to negative. Each capacitor has a negative terminal, each mount location has a negative hole and it is indicated by the wide black band. After you insert each part, fold the legs over on the solder side of the board so that the part does not fall out and stays in position. Once you have all the parts reinstalled, solder them in. Make sure you make a clean electrical connection. Now use your wire cutters to trim the excess legs. Be sure to trim them close so that they don't touch any other electrical connections on the board.
Your SMPS is now fixed and ready to go... reinstall it into the TV and connect the wire harnesses back up to the SMPS. Double check your work. Are all the connectors back in place? Ok, now you should test your work before putting the whole TV back together. Prepare the AC cord, use an extension cord if needed. You will need to flip the TV up on to its top edge (upside down, screen facing you). Plug the AC cord into the TV and press the power button. Do you see the Video/Input indicator or RF snow on the screen? If so, well done! If not, unplug the TV and check you work.
You are now ready to reassemble the TV and return it to service.
** If you need some assistance in the soldering area, please have a look at my Tip "Soldering on the kitchen table, Class 101". I cover the actual soldering of a capacitor in more detail there.
If you have found this helpful, spread the word and/or leave me some feedback.
on Jan 19, 2011 | Televison & Video
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
Samsung LNT4661FX/XAA 46 in. HDTV LCD Television - When tv is turned on it makes a clicking noise for about 15-16 clicks. Progressively worse. Finally comes on
Capacitors are bad on the power supply board, they will probably looked bulged at the top. I've enclosed an example.
Jan 02, 2011 | Samsung Televison & Video
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 27, 2010 | Samsung LNT4642H 46 in. LCD Television
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
I am having a problem with my Samsung LNT4661FX/XAA
http://techreport.com/search_google.x?cx=010312586752609289257%3Avgpois-b0yw&cof=FORID%3A11&q=LNt4661fx&sa=#692
check this link for more info on the power supply problem.
May 01, 2009 | Televison & Video
Sep 07, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Samsung LN-T4061F 40 in. LCD HDTV Logo
743 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
