When I start my computer I get the message: 'Extender Fatel Error Invalid or missing resaurce files in teh installation directory. Please reinstall Extender Player.' What do I do about this?
  • d_thuet May 25, 2011
    That did it, just one more question. I did have a side bar to the right that had a clock, calendar and money converter amounts ($ to € and $ to £). How do I get this back?
    Thanks for your help
    Dennis
  • 670 Answers
do you get this message when you turn the computer on or do your get this after logging on to the desktop?
if you are getting this message after logging on to the desktop please do this:
1. on your keyboard press and hold the windows key, while holding it down press the R button. 2.when the Run box comes up type in msconfig 3.you'll see the box called system startup utility, look for the tab called startup 4. at the bottom corner click disable all 5.click apply and ok or close (whichever applies) and restart the computer
Hopefully this helps!
Posted on May 25, 2011
  • Marlon Deza
    Marlon Deza May 25, 2011
    I'm glad it did the trick for you. to bring the sidebar back go to the run box again and open msconfig
    go to Startup and then check the details at the command column see which one says "C:\ProgramFiles\Windows Sidebar\sidebar.exe" might not be the exact message but check for anything that says some about the sidebar. Put a check mar on it click apply and ok or close and restart the computer.
    Are you using windows 7 or windows vista? if the steps above doesn't help let me know what windows you are running so I can give you a much detailed step by step guide.
    Thanks!
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
Nov 06, 2013 | Microsoft Windows 7 Home Premium for PC
I seem to have accidently downloaded an invalid file system onto my Epsom P6000. I can't enter into it anymore, the message on the screen says 'invalid file system, please turn power off'
hahaha.... thats only a mutimedia viewer... you cannot actually install programs there...
just remove the invalid file on your storage... update your firmware and reboot...
Jan 19, 2013 | Computers & Internet
When i Start the game.Then it comes an error.SAYS(Fatal error: Couldn't flip Directx message: Unknown error)
The problem with your game is that the DirectX component compatible with the game is not installed properly or there are some files missing in the DirectX directory.Try re-installing the DirectX.
Thank You
Dec 26, 2012 | Project IGI IM GOING IN
Invalid or missing resource files in installation directory.extender player
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
To automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart.
You should have no input while chkdsk utility is in progress any input might further damage your computer it be patient might take some time depending on the size of your hard drive.
Try opening Computer Management from Start Search Bar. Follow the location to open computer management.
Click on Start
In the Start Search bar type Computer Management and hit enter and check if you are able to open it.
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
Open an elevated command prompt.
To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
Type the following command, and then press ENTER:
sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
hope it helps
Nov 12, 2012 | Acer Aspire 5560-7851 AS5560-7851 15.6"...
Reinstall Extender Player
AJay you should not be in forums you are so rude. dont call people peabrain. you could use a typing class yourself.
Apr 07, 2012 | Microsoft Windows 7 Home Premium 64BIT...
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
May 30, 2011 | Microsoft Computers & Internet
Installed The Print Shop 2.0 Deluxe on my Windows XP, SP3 & seemed to install fine. Won't run, gives me error message - "The configuration file is missing or invalid; you may have to repair...
Hello there, At first, go to start menu, all programs, accessories, system tools, open System Restore. Restore your system to restore point created before installing The Print Shop. After that, try to install it again. Otherwise, you can try to install it from different CD, or installation file. Sincerely, Steve TM
May 28, 2011 | Computers & Internet
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
