SOURCE: transcend 1 GB removeable Pen drive is not detected
The pen driver is ifected with virus.Just format it with CMD and ur problem will be solved
SOURCE: Pen drive is not able to write any data
How are you formatting it? NTFS or FA32?
I suggest you reformat as FAT32
SOURCE: transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
SOURCE: how can open my pendrive without format
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
SOURCE: my pen drive is being detected but is not showing the data
Rt click the pendrive and click properties ..uncheck the readonly file option ....apply ok ..
What operating system did you write the data with?
