Question about Philips 50P8341 50" Rear Projection Television
Too much red - Philips 50P8341 50" Rear Projection Television
  • Philips Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
too much red - 69189a5.png/>69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 02, 2011
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
Feb 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Red
Sorry, your red crt (picture tube) is bad, last time i called sony they were no longer available. Have your tv guy turn down the red drive on your screen control (inside the tv chassis , you should not do this !) it may stop the bright red for a while.
Jun 11, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Picture red
red screen is due to problem in red video circuit. please check 1 supply to red video ckt. 2 crt base loose. 3 components in red video ckt. 4 loose contact in red cathode ckt in crt base. 5 red video transistor. 6 signal coming to red video from signal processor. 7 signal processor ic. as per schematic check web site www.serviceinfo.com good luck.
Sep 29, 2007 | Televison & Video
Red picture
if picture is red & DARK PLEASE componemts of red cathode ckt 1 red video supply 2 ckt & loose contact near red ckt 3 red signal is coming to red video from signal processor 4 crt base loose 5 red signal processor ic. schematic www.serviceinfo.com good luck
Sep 28, 2007 | Televison & Video
Red screen
how to lower the red screen voltage?
Nov 07, 2006 | Sony KP-53HS30 53" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
