Question about Car Audio & Video
All four windows have no power radio has no power and dome light wont come on
  • 670 Answers
Does the car start properly? if it does it means that you have an wiring problem, the wire supplying power to the doors the radio and the dome might have tripped, could have had a short circuit etc. have that checked by a local electrician to make sure.
PS don't forget to check the fuse box see if all fuses are good because it could be that those have blown off.
hope this helps!
Posted on May 25, 2011
Why 01 Tacoma radio wont power on,why this is a major problem and repeated question and no straight answere
There is no "radio" fuse.
The radio gets its power from the "ACC" fuse and the "DOME" fuse. Each one is on a different fuse box. If the dome light works its not that fuse. If the shift lock and cigarette lighter work its not the ACC fuse.
Nov 19, 2015 | Cars & Trucks
Installed new radio in 2007 chevy silverado 3500, now no dome light, no power locks or windows... What happened?
Check the fuses. Sounds like one or two got fried during the radio install. Use test light to test all the small fuses with ignition on
Feb 28, 2015 | Chevrolet Silverado Cars & Trucks
Power windows power seats radio dome lights do not work
The controller has failed and needs to be replaced or reset by the factory technician.
Apr 01, 2014 | GMC 02 03 04 05 Envoy Chevy Trailblazer...
2002 Lancer CE dome light fuse location
The dome light feed comes from the ETACS ECU. There are four fused inputs: 7.5A multipurpose fuse 2, 15A multipurpose fuse 14 and, in the enngine compartment relay box, 10A DEDICATED fuses 17 and 18. One of these four should apply to the dome light
Oct 13, 2012 | 2002 Mitsubishi Lancer
Radio wont hol memory, dome light wont work when key switch off, and All lock wont unlock doors unless key in on.
Probably a fuse. You radio keeps it's memory using a constant power wire which is probably interlinked with the dome light, door locks, etc. Check fuses under the dash as well as under the hood for any blown fuses. Look for fuses labeled with your listed problems of things that don't work.
Jul 07, 2009 | 2002 Honda Civic
98 toyota corolla radio, dome light, and power locks don't work
2005 toyota corolla radio,dome light,alarm and power locks dont work.
Apr 26, 2009 | 1998 Toyota Corolla
When I shut off the ignition the radio and dome light stayed on
I have the same truck. The thing is designed so that the radio and dome light and even the windows will operate for a time which should expire immediately when you open the door. Try turning on the radio with engine running and then turn off the engine and just sit there and the radio should still play. Try the power windows - they too should go up and down. Finally open the drivers door and that should immediately kill the radio, windows and dome light. If it does not - you will need to report that problem to your dealer since the problem is in that timer feature which is part of the vehicles "brain". Sorry I can't be more helpful.
Dec 19, 2008 | 2003 Ford F250 Super Duty Crew Cab
Dome light stays on, power windows don't work... 1999 Jeep
Check for a broken 12V+ or broken ground wire in the rubber boot that goes from the drivers door to the hinge pillar. Had this problem on mine and found both wires broken from years of flexing when door opened and closed. Don't try to splice the break, as the wire is too short and is also brittle. Run new (same guage) wire through the boot and splice inside the door and under the left side kick panel.
Nov 11, 2008 | 1999 Jeep Grand Cherokee
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
