Question about Car Audio & Video
I HAVE A 2004 NISSAN TITAN KING CAB TRUCK. IT IS AN AUTOMATIC TRANS, BUT I AM ABLE TO CHANGE IT OVER ON MY SHIFTER TO MANUAL. WELL I TRIED TO CHANGE IT OVER AND ITS NOT LETTING ME. I AM NOT HAVING ANY PROBLES WITH MY TRANS. WHEN IT COME TO SHIFTING OR SLIPPING OR ANYTHING LIKE THAT. CAN ANYBODY HELP ME!!!!!
  • csoukhakian Aug 16, 2008
    all it will let me do is put it in drive, reverse, nutral, and park when i'm using the shifter on the tree (automatic) it won't let me put it in 1st. gear or 2nd. gear and then when i try and push the button on the tree to make it manual....it won't let it go into a manual tran. and let me shift when i want
    well it won't go into manual mode at all, so yes
  • 474 Answers
It won't let you shift like a standard but it will let you shift and stay in other gears at any RPM's
Posted on Aug 16, 2008
  • mike watson
    mike watson Aug 16, 2008
    when you push the toggle on the shifter for the gears you want it still won't shift?
I have alpine sps600c & am installing them in a 2001 Nissan frontier w/ 6 disc 6 speaker (2 ea in each ront door, 2 in back (crew cab). Do I wire my tweeters to existing tweeter output, or...
Did you change out the factory deck? If not, wire the tweets to the existing wiring. If you already have tweets they have been crossedover already. However, if you replaced the deck, you may need to run new wire to the doors and use the crossover that came with your component set. Hope this helps
Sep 05, 2011 | Alpine SPS-600C Car Component System
Trying to install kenwood kfc-1662s speakers in my 07 silverado crew cab and having problems mounting the speakers in. is there a mounting bracket that i need for them?
These speakers are not designed for your truck. I recomend asking chevy of what brands and what size speakers will fit in your truck.
May 15, 2011 | Kenwood Car Audio & Video
Does not engage when put in 4 wd but when put in 4 L transfer case goes in 4 low but no front tire drive??
It sounds to me like you either have a problem with the splines between the left axle shaft and left side gear in the differential, or you have side gear or spider gear failure.
The next step is going to be to inspect the spider and side gears in the front differential.
Based on all the information you've given, it almost sounds as if the problem is in the differential.
Although, you should also make sure your truck is either in Park or Neutral BEFORE you engage the 4WD if you haven't tried that yet. I'm sure you probably already knew to do this though...
Best of luck with your truck! Hopefully this helps guide you in the right direction to getting it repaired!
Best Regards,
James
Dec 18, 2010 | MTX Audio ThunderForm DRQC20AT Custom-Fit...
MHi i just reciently purchased a nissan navara D22 series 2004 ute. The radio is asking for a pin number and in my owner manual there has been no information filled out. Was hoping u could help
Take it to a nissan dealer they should be able to access records of it along with the radio code.It happened to me it cost about 20 euro to get the code plus the garage will keep the info on file if it ever happens again
Oct 09, 2010 | Car Audio & Video
Shifter feels like it is broke and truck is in gear, how can I get truck in park
get under your truck then feel on the side of your gear box and there is ia lever about 3 inches long this is your selector it should be attached to your shifter if it IS still attached then your gearbox is fooked
Dec 14, 2009 | MTX Dodge Ram Quad Cab 2002-2003...
I have a 2004 Nissan Titan Pickup Crew Cab with Rockford Fosgate Speaker System; without Navigation system. i have a laptop that i plug into the aux cable to play music with but when i plug it into the...
Hello kennycalve1,
It sounds like you picking up noise from the inverter itself. There's a transformer on the output that changes direction 60 times a second to produce the AC. A signal will radiate a short distance from the inverter and is being induced into the other wiring. I'd try plugging the inverter into another outlet in the vehicle (perhaps in the back) and maybe install a "Rube Goldberg" shield. Likewise, use a shielded cable from the laptop to the AUX input and put a "ferrite bead" on the output end. Use a large bead and wrap the cable one turn through the center.
Hope this helps.
Jul 21, 2009 | Rockford Fosgate Car Audio & Video
Need subwoofers
IF U HAVE A REG CAB U CAN BUY A TRUCK BOX MOSTLY FITTING 2 10INCH SUBS, AND A AMP UNDER YOUR SEATS, OR IF U HAVE A LARGER CAB THEY MAKE CUSTOM FIT BOXES BUT THEY WILL COST U MORE, OR U CAN GET A BOX FOR 1 12INCH SUB FOR A TRUCK AND U CAN PUT IT ANYWHERE U WANT.
Jun 16, 2009 | Car Audio & Video
I need cd redio code for nissan micra 2004
Check in owners manual. If not there take to dealership
Dec 03, 2008 | Car Audio & Video
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
