Question about Toshiba (5105-S701) Graphic Card
My laptop show a blue screen & restart after an hour or half an hour while i''m using it. i thought is a hard drive failure. please help
  • Toshiba Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Posted on May 25, 2011
Hi everyone, I was installing windows xp sp3 on my compaq desktop computer through my hard drive because my computer doesn't recognise cd roms, So I can't install through cd drives. It installed to...
Hi
Have you tried to go into your cmos settings and enable the settings to detect your cd rom
You should be able to use a external cd rom connected through your USB port to load and re-install windows and your drivers if you have the motherboard cd.
The problem is your limited in your options to work from the hard drive but a disk also gives you the option to repair the filing system and replace missing files.
The problem with installing windows on one pc and it not working on another pc is the motherboards are not compatible, and the configuration has to be similar or the same so the hard drive can boot up and communicate between the hardware and software.
Your options are use a CD rom, change your MB or google your problem and hope someone else was able to resolve this issue.
Cheers
Nov 26, 2012 | Computers & Internet
My thinkpad t43 26684du screen goes very dim after use (half hour). when i reboot it won't shut down until i remove battery. restarts fine for a while. irun win 7 ultimate all updated.
There is two problem possible for these symptoms:
1st one is due to inverter
2nd one is due to screen backlight lamp (CCFL)
You need technical support. We may need some components to be changed. If you think you can do it on your own, see http://www.laptoprepair101.com/laptop/2007/09/05/troubleshooting-laptop-with-backlight-failure/
Nov 05, 2012 | Computers & Internet
My toshiba L745-s4235 laptop is shutting down randomly
Sounds like a failing hard drive or it has some bad sectors.
Oct 19, 2012 | Toshiba 14.0" L745-s4235 Satellite Led...
Blue screen error plus blank start up screens but the start up sound can be heard.
Have you changed any BIOS settings? I would open your BIOS menu and make sure it is set to "AHCI"
Aug 21, 2012 | Lenovo IdeaPad U550 Notebook
My pc compaq nc6220 cannot boot,some time it show disk controller failure,some time no disk system or disk error and som time a blue screen appear on my screen.please help me.
Your hard drive may have crashed.This is so proven by the 'blue screen' technically referred to as 'the screen death'.
  • First,you may try removing the hard disk,leave it for a while and re-fix it again.Start the PC.What happens?
  • If still wont start, you may have to try and re-install the operating system again.
  • If the operating system wont install on the drive,replace it.
Hope this helps.Thanks!
Please rate this answer.
Oct 22, 2011 | HP Compaq nc6220 Notebook
How to fix a dell inspiron 8100 boot.When i tryed to boot frome a driver cd that was not for my computer i tryed to boot frome it but would not boot so i turned it off and tryed to boot frome my hard drive...
Hi ethandown,
From my experience, you most likely have a corrupted hard drive which has affected your Windows Installation. Your only option may be to boot from a Windows XP cd.
-When your computer starts, press F2, sometimes delete to enter the system options and change the boot-up priority device to cd/dvd 9(1st).
- Restart the computer putting your windows xp setup cd inside. It will ask you to press a button to run from the cd.
- follow instructions and when on the blue screen, use the repair windows installation.
-if that doesnt work, you may have to reinstall windows however your old files will still be on the hard drive.
Hope this helps,
kc
Feb 21, 2011 | Dell Inspiron 8100 Notebook
I have Compaq V6000 series laptop with AMD Processor & nvidia graphic card ,my laptop?s lower half of screen becomes blurred & will become ok after some adjustments & again become blurred when...
There was a TSB about the motherboards on the V series describing severe video issues and Nvidia GPU failures. Many consumers got a motherboard replacement. Try using a laptop cooler in the meantime and see if that helps a little. Also try googling V6000 video and see how many others got nuked by this poor design.
Mar 13, 2010 | Computers & Internet
What does Operating System not found mean?
If you see this message during power on start up then there are two possibilities.
1. The computer is trying to boot from a drive other then the internal hard drive. Optional bootable devices include:
a. optical drives (CD/DVD/Blue Ray)
b. thumb drives (memory cards, USB drives)
c. external hard drives.
To correct this problem then remove the media (CD, DVD, Blur Ray, memory card or external hard drive) and restart the system normally. The computer should boot into the Operating system.
2. The computer's internal hard drive has been corrupted and the information required to boot the operating system is not readable. There are few different reasons for this including infections and hard drive failure.
If this is the case, please seek professional services to rectify the issue as serious infections and hard drive failure are problems that require advanced tools and methods to fix.
Feb 05, 2010 | Microsoft Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
