Question about NorStar M7324 Telephone
I don't really have a solution per say but I have some advice. Whenever I have phone system problems (ours is Toshiba) I post on the forums at Sundance Communications http://www.sundance-communications.com/forum/ultimatebb.php The folks there are extremely knowledgeable and always offer good and quick advice. Hope this helps.
Posted on Aug 18, 2008
The following steps will help you to set an alternative greeting and play it back and forth...
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Pres the REC softkey
6. Press the ALT softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end
your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have
your voicemail box accept messages while your Alternate Greeting is
turned on, or press the CHNG softkey to change the "Y" to an "N" if you
do not want your voicemail box to accept messages
Thank you...Regards!...
Posted on Aug 15, 2008
Here is the owners manual.
i hope this helps
SOURCE: Nortstar M7324
In order to record an alternate greeting, you sign into your voicemail. Select Admin, Select Greet, Select Choose (and select which greeting you would like to use eg..Prime or Alt) Once you select the greeting. The voicemail is set to use that greeting. To record that greeting, go back into Admin, Select Greet, Select Rec, and record and save your greeting.
Posted on May 11, 2009
Feb 10, 2015 | Samsung Galaxy S 4G Cell Phone
Apr 24, 2014 | Mitel Superset 4150 Like Phone
Dec 12, 2012 | Lands Phones
Mar 09, 2011 | Panasonic KXDT321 Phone
Dec 21, 2010 | Samsung DCS 12 Corded Phone
Mar 11, 2010 | NorStar M7310 Corded Phone
Dec 22, 2009 | NorStar M7310 Corded Phone
Oct 14, 2009 | NorStar NT5B74 2 Channel Applications...
Jan 15, 2009 | NorStar T7316E Corded Phone
May 30, 2008 | NorStar M7324 Telephone
Mar 14, 2016 | NorStar M7324 Telephone
352 people viewed this question
The following is the advice we've gotten. We've tried this many times but it still defaults to the primary greeting even if we choose alternate greeting on. We are able to follow all the steps all the way except for the very end, step #12. We can't do because the phone does not give us an option to "Accept msgs: Y or N"--this message never appears. Maybe the advice was for a different model phone? Our phone model is M7324.
d.
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages
