Hi I installed a pci videox16 in my computer. Worked fine all day. Shut it down took it home and started up monitor came on noticed i forgotton plug the keyboard in.I shut down plugged the keyboard in and my monitor would not come on no display at all. When i set it up i was using a usb keyboard,does that have anything to do with it.I unplugged the monitor for a while booted again still no display. How can i fix this i can get a usb keyboard but is that my issue. The reason i got the new video was because i thought the onboard had a problem after i switched from my wireless to the onboard keyboard plug in.my monitor would not turn on. Now the same thing plug onboard keyboard and no monitor. PLEASE HELP
ImWireless
  • 113 Answers
SOURCE: Keyboard problems.
1. Restart the PC. 2. Hit F12 key repeatedly as soon as the PC turns ON. This will bring up the Boot Menu. 3. Select DELL Diagnostics. 4. Select the Complete / Full from the list of options. 5. Let the tests run which may take about an hour. Make sure you are there in front of the PC for the first 10-15 minutes, because it would need your inputs. 6. This will test the keyboard and USB ports too. 7. This will also verify for you whether the keyboard works when Windows hasn't started. 8. If all the tests pass and your keyboard is still working after sometime, you have issues with Windows: Start you computer in Safe Mode and check the USB drivers and the keyboard drivers. 9. Now, if you continue having issues even when you are running the diagnostics, you need to check your hardware viz. keyboard (try installing another keyboard if you have one) and the USB port. PLEASE REVERT BACK WITH THE RESULTS. I WOULD LOVE TO HELP YOU FURTHER ON THIS, IF THE ISSUE CONTINUES.
Posted on Mar 08, 2007
SOURCE: Dell XPS 400 no power to usb or pci slots
I have had the same problem with my dell xps 400. What I did was purchased a usb power hub and that solved the problem for me. SAved me from buying a new mother board.
Posted on Dec 10, 2008
nickpower
  • 43 Answers
SOURCE: k9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
MY GUESS IS THE NORTH BRIDGE ON MOTHER BOARD IS BAD, REPLACE MOTHER BOARD.
Posted on Dec 19, 2008
KenKaBob
  • 89 Answers
SOURCE: Keyboard and Mouse don't work anymore
Hi, Sorry you are having problems,
Well Marcelo, the first thing to do in a situation like this is to restart your Mac or even better, shut down and restart. So, if you have done this, and still the keyboard and mouse don't respond, and, as you have mentioned, you have tried the other USB ports on the back of the Mac, it sounds like somehow, unexpectedly, your iMac motherboard got a shock of some kind and it killed the USB controller....
Last thing to try is to unplug the iMac completely of everything and let it sit for 10 minutes and then plug just the keyboard and mouse back in and try to see if that does the trick..
Otherwise, Apple will cover this if it is still under warranty.
Good Luck.
Posted on Apr 02, 2009
  • 44 Answers
SOURCE: I can't install a GeForce 6200 graphics card
Also, if that card has dual outputs, such as 2 DVI connectors, try connecting your monitor to the other one.
Posted on Jul 19, 2009
Acer Aspire 9300 My Aspire 9300 has worked fine
It maybe the problem of your graphics processor,so you can't see the NOOK working normally .Your Acer Aspire 9300 battery haven't effect to this mattery ,why you tried taking it out !
May 18, 2010 | Acer Aspire 9300 Notebook
2nd monitor doesnt work either
Ensure your are running the monitors in dual mode still. Open your Nvidia Control Panel and click on "setup up multiple displays" Then on right panel you should see where to select your option on how to run the 2nd one. You might need a driver update from Nvidia, especially if you recently took an update from Microsoft.
Hope this helps
ps Here is the link to Nvidia: Click Me
Sep 26, 2009 | Pine Technology XFX GeForce 7950GT, (512...
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
I have an old computer with an asus motherboard, When I turn on the computer it boots up and goes to the windows xp window but then the monitor screen goes white and never goes any further thoug the...
It sounds like Windows might be loading a bad driver for your main PCI (assuming it's PCI) slot. Try plugging your monitor into the motherboard instead of the video card. Try re-installing your graphics card driver to the latest version, you can download these drivers through the company's website and looking for your video card's model. After re-installing the drivers, shut down your computer. Put your videocard in it's main slot and plug the monitor to it. This should do the trick.
Mar 25, 2009 | Computers & Internet
Backlight Issue
There may be a problem with the power supply such as a missing voltage output.
Jul 24, 2017 | Princeton Digital LCD1711 17" LCD Monitor
I have a computer in my upstairs guest room and two computers on the first level of my home. One has a USB adapter and works OK but looses the signal at times. The othe has a PCI card installed and is...
you need to contact belkin they will walk you through the setup to change your channel so that all of your computers are on the same signal. i would do this but i have unfortunatly forgotton how to do it...
Aug 15, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Kogie monitor
check your graphics cards settings in the bios.
set to AGP/IDE as appropriate.
use another monitor if necessary.
Also check the graphics card i.e on-board or PCI/AGP Cards functioning correctly.
Mike @ compurepair.
Feb 24, 2008 | Computers & Internet
Problems with Mobo? Or CPU?
Hi, have you checked your RAM chips? Could be they have worked loose while traveling, make sure they are firmly seated, otherwise you may have to take it to a technician. Goodluck mistyman
Sep 04, 2007 | Gigabyte GA-M55SLI-S4 Motherboard
Monitor doesn't work
When you got the pc, you should have been given a starter pack with some CD-ROM's in the pack, one of them should be the drives for the monitor, you might need to use anothermonitor to see the instructions, but the basic graphics card should power the monitor enough to set things up, until then you won't be able to adjust the settings.
Apr 17, 2007 | Kogi L7CH Monitor
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
