Question about Western Digital WD AVGP WD10EURS WD10EURS 1 TB Hard Drive
WD10EURS visible in Bios, but not to be found in XP
  • 394 Answers
Start your PC .
Right click on the icon my computer on the desktop.
Select Manage->Go to Disk Management.
Here you can see your Hard Disc but unallocated .
Format it and it will work.
Thanks for using FixYa.
Posted on May 25, 2011
  • Western Digital Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Operating system not found acer aspire 3500
Make sure the hard drive is visible in BIOS, if it is you will need to re-install the operating systems.
Dec 03, 2012 | Microsoft Windows XP Home Edition English...
Tip
DVD drive not found issue in windows 7
In some cases your DVD drive may not be found by Windows 7, even if it's visible in the BIOS and using the standard driver.<br /><br />The standard solution here is to run <span style="font-weight: bold;">REGEDIT</span>, and navigate to <br /><br /><span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\</span>, <br /><br />then delete both UpperFilters and LowerFilters in the right-hand pane (UpperFilters.bak and LowerFilters.bak entries can be ignored).<br /><br />If its not working you can try resetting the drive letter .To do that,<br /><br />Go to <span style="font-weight: bold;">Start</span>, type <span style="font-weight: bold;">Disk Management</span> and choose the <span style="font-weight: bold;">"Create and format hard disk partitions</span>" link. If your optical drive is visible here then right-click it, select Change Drive Letter and Paths, click Change and choose a new letter. If the drive is now visible in Explorer, then repeat the process to change the drive letter back; if it's still not visible, reboot and it should appear.
on Nov 10, 2010 | Computers & Internet
Tip
"DVD Drive Cannot Be Found in windows 7"
Solution: In some cases your DVD drive may not be found by Windows 7, even if it's visible in the BIOS and using the standard driver.
This might cause because of a registry hack aswell.
The standard solution here is to run REGEDIT, browse to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\, then delete both UpperFilters and LowerFilters in the right-hand pane (UpperFilters.bak and LowerFilters.bak entries can be ignored).
No change?
Resetting the drive letter has worked for some.
Click Start, type Disk Management and choose the "Create and format hard disk partitions" link. If your optical drive is visible here then right-click it, select Change Drive Letter and Paths, click Change and choose a new letter. If the drive is now visible in Explorer, then repeat the process to change the drive letter back; if it`s still not visible, reboot and it should appear.
on Jul 13, 2010 | Computers & Internet
HannStar J MV-4 (jumper clearcmos/reset bios) password initial wrong setup bios heeeeeellppp.
The location of the jumpers or dipswitches may vary; however, here are some locations of the jumpers / dipswitches.
  1. On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
  2. By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual CMOS battery.
  3. By the processor - Some manufactures will place the jumpers by the processor of the computer. However, note that in some cases these jumpers will be to change the processor and not the password.
  4. Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
  5. Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
  6. Jumpers may also be found underneath or allongside the memory modules.
I hope this helps but suggest that the manufacturers web site or your instruction manual, may have the answer.
Oct 23, 2010 | Computers & Internet
Hard disk not found error during Clean XP home Install
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
Problem with ibuddy ECS A900
Found out computer got so hot DC plug melted;
The thing is that it had a poor Ground so ran my own Ground.
Works Fine Now Bill
Nov 21, 2008 | Computers & Internet
ECS p4m800pro m2 Onboard Network Adapter does not show up in windows
Try disabling the network adapter in the bios and removing any network adapter in device manager in Windows
Then reboot
Windows so it thinks there is no network adapter.
Then
Reboot into bios and re-anable the onboard network adapter.
Then see if windows detects the network adapter now that it is enabled.
Mar 03, 2017 | Computers & Internet
Kta pro v1.0 bios problem
You are right - a new BIOS upgrade should give the proper displays. Go to the motherboard's manufacturer's website to download the latest bios.
Sep 01, 2008 | Computers & Internet
How to install xp on hp 530
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Western Digital WD AVGP WD10EURS WD10EURS 1 TB Hard Drive Logo
113 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
