I had external hard drive got a new casing just want to know how to put in new casing
    Genius:
  • 1,127 Answers
Hi
Which type or external drive you have (PATA) or (SATA), connect your driver to your External drive case, The external drive case have both of connector to connect the drive, chose your drive and connect the drive and connect the power, that ok
Now close your drive case and USB one side put in external drive case and second side put your Com/Lapi and switch on your external drive, your com/lapi detecting your external drive and your see the my computer external drive now what ever data you want to store, copy
and enjoy
Posted on May 25, 2011
I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
Hope this helps!
Regards,
Joe
Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
My external hard drive had the click of death. I
YOU HAVE TO PUT IDE OR SATA CABLE TO THE DRIVE AND ONE MORE THING IS 4 PIN SUPPLY FROM SMPS.YOU HAVE TO PUT CONNECTIONS LIKE THE FIRST HARD DRIVE ALREADY IN THE COMPUTER
Apr 04, 2010 | Computers & Internet
If the usb plug is loose on the back of an external hard drive, and has worked less and less, now not at all, can anything be done to replace it? Is this something that can be fixed so my external hard...
if the plug is getting loose you probably can't repair it
the only thing you can do is to open the plastic case, remove the hard disk and put it in a new enclosure.
emove the hard disk from the plastic case and put it in a new
Jul 29, 2017 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
My computer will not recognize my external hard drive
the external hard drive's motherboard is burnt take it apart (this will be a little hard but it will come apart) after you take apart u will see it is just an internal hard drive in a case so either...
1) put it inside your computer as an internal or..
2) buy a new external hard drive case (that will have a new hdd motherboard in it)
after you install it either way your computer will reconize the hd and WORK i done this just yesterday.
Nov 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
No power on WDelements WD5000
It's not a new hard drive casing that you need, rr_atl, it's a replacement power supply. Western Digital is well know for selling very poorly manufactured power supplies with this hard drive series. The problem you described is a bad power brick.
Jul 31, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
My current hard drive is running really low...
An external drive would be a possible solution. You could also buy a new internal drive (be sure it is the same interface), buy a 2.5" external usb case, and mirror the data over to the new one. You could then install the new drive into the computer, put the old one in the external case and either use it as a backup or an external drive.
Apr 25, 2009 | Dell Inspiron 6400 Notebook
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
GETTING INFO FROM OLD HARD DRIVR TO NE LAPTOP.
Hard Drive requires lots of power to load. If you have purchased only the IDE cable to connect it to USB port, USB port will be unable to initialize the Hard Drive.
To make it work,you require an external casing for IDE Hard Drives with external power support. Like this one --
http://shopping.rediff.com/shop/productdisplay.jsp?3.5Inch-USB-2.0-EXTERNAL-Casing-For-SATA-/-IDE-Hard-Drives&prrfnbr=10209520&source=browse&frompg=Hard%20Disk%20Drives
If you already have this casing with external power support, please let me know.
Nov 15, 2008 | Computers & Internet
External hard drive not openning
Good News, Your data is probably still safe. Go to best buy or online and buy a new cheap external usb case for your harddrive. you can find them for about 7-25 bucks. Make sure you get the right one for the hard drive in your lacie. Take the hard drive out of the lacie case and put it in the cheap case and you will have your data back. I had this happen to me before. If you need help just ask me... Hope this helps you
George
Jul 15, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
