Question about Nokia E50
I am using nokia e 50. i want to use the infrared facility. but i could not find the IR port. can you say that where it is located.
    Scholar:
  • 99 Answers
The IR port is located just under the volume key.
Posted on May 25, 2011
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Samsung HL-T5076S 50 in. TV
Nokia 6610i connection to macbook 2,1 model through infrared channel
Please clarify. If you have IR port on your Mac and you have IR transmitter on your Nokia then there'd be no problems.
Oct 02, 2012 | Nokia 6610i Cellular Phone
Fitting infrared attachment on D3100
The ML-L3 cannot be used with the D3100. An alternative wireless remote is this one. It's not an external IR port but a radio receiver.
Feb 02, 2012 | Nikon D3100 Digital Camera
How to use infrared port in sony ericssion k220i . what is main use of infrared port. what can i do using this facility?
The infrared port is by the left side of the phone, it is along the line that splits the front and the back of the phone. It is mostly covered by a thick red glass or plastic.
Infrared is a device on a phone that allows you to send and receive file using the infrared radiation wireless wave. It works like a bluetooth device, just that it must be placed close to the infrared port of the phone that is sending or receiving files from. You cannot send or receive files that does not have infrared using your own infrared.
Infrared can be used to send and receive files (data, song, pictures, videos etc).
To use the infrared of the sony ericsson K220i, you have to go to your phone 'menu', go to the 'settings', select the 'connectivity', then you select the 'infrared', turn it 'on', when you are to receive a file, you place your phone close to the sending devices infrared port. Also when receiving a file, you do the same.
When you want to send a file through infrared, you go to the file you want to send, you select the option, select send from the option, a pop up blog will come up asking you how you want to send the file, you select via infrared and your infrared will come on, the device you are sending it to would have its infrared turned on as well. The infrared ports must be placed close to themselves before the files can be sent.
Take care
Jun 25, 2010 | Sony Ericsson Cell Phones
I don't know how enable infrared port in my pc - ibm thinkpad x 41
By default, currently available ThinkPads come with the external serial port disabled and Infrared enabled on COM1. To use the serial port on COM1 you must either disable infrared or change infrared so that it uses alternate resources. If you are not using infrared for printing or file sharing it is recommended that it be disabled. Here are the steps to follow to enable infrared :
1. Double-click your ThinkPad Features or ThinkPad Configuration icon located in the ThinkPad folder on your desktop.
2. Locate the Infrared button located on the left-hand side of this configuration screen and click it once. (Note: If you hold your mouse pointer over any of the icons in this configuration screen the button will be identified at the bottom in the status window.)
3. Change Infrared from "Disable" to "Enable" and click "OK".
4. Locate the serial port icon and click it once.
5. Select serial port "enable" and insure that the COM PORT setting is "COM 1" and click "OK".
6. Shut down and restart the computer.
Jan 19, 2010 | IBM ThinkPad X41 Notebook
My dell D505 turned itself and will not turn back on power light flashes but thats it power supply is fine
  1. Locate Fast IR under Onboard Devices.
NOTE: Ensure that the COM port that you select is different from the COM port assigned to the serial connector.
  1. Press <Enter>.
  2. Use the arrow keys to select the infrared COM port setting.
  3. Press <Enter>.
  4. Follow the instructions on the screen.
After you enable the infrared sensor, you can use it to establish a link to an infrared device. To set up and use an infrared device, see the infrared device documentation and the Windows XP Help and Support Center
http://support.dell.com/support/edocs/systems/latd620/en/UG/setup.htm#wp1112328
Dec 26, 2009 | Dell Latitude D505 Notebook
Where is the IR port located?
The IR (Infrared) port is located in the front for easy line-of-sight linking to other IR capable devices.
May 01, 2009 | Dell Inspiron 9100 Notebook
How to connect my pc to my cell-phone using infrared connection
Not all PC's have IR ports.  You'll need to check the system BIOS, see if there is an option for and IR port and if there is ensure it is enabled.  Once enabled, it should be listed as a device in Device Manager.  If you need further assistance, post the model of the system and the Version Of Windows installed so we can give you more details.
Oct 12, 2008 | Nokia 6020 Cellular Phone
Transfer images from mobile to computer
i have Nokia 6630..i want to tranfer images from my mobile to pc through USB but i dont know how to connect it & i dont know how to use it..can you help me with this problems?
May 29, 2007 | Nokia Handsfree For 6020, 6101, 6102...
Synchonize
To synchronize your Toshiba Pocket PC (e570, e310, e740) with your notebook over a Infrared connection, please follow the below instructions: Ensure that the Microsoft program ActiveSync is installed on your notebook Ensure that the infrared port of the notebook is enabled Line up your Pocket PC IR lens with the IR-lens of the notebook On your Pocket PC, please on to "Start" and select for the menu "ActiveSync" Tap with Pocket PC pen on "Tools" in the left lower corner and select "Connect via IR.." The synchonisation will start automatically. Simple follow the on screen instruction to complete the process Please see below:
Sep 07, 2005 | Toshiba e310 Pocket PC
Nokia E50 Logo
42 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
