Question about Fisher and Paykel SmartLoad DG62T27G Dryer
I noticed after the last couple of loads of clothing in my Fisher and Paykel dryer that the stainless steel on the right hand side of the dryer was extremely hot. In experimenting, it would cool down when I just used air cycle but as soon as I turned the machine off and checked it a few minutes later the metal was hot again. I turned the dryer off at the box and it cooled down. Today out of curiosity I flipped the dryer switch at the main box and even though the dryer was not turned on, the metal and dryer got hot again. What on earth is going on. I had a F & P washer, the business where I purchased the pair about four years ago closed and this is a small town. I found that it would take some time for a repairman to come out and look and then they would have to order the parts and come back. By the time all was figured it was going to cost around $370 for the problem on the washer so I purchased a new machine. I am afraid to run this dryer for fear it will start a fire. Thank you so much
  • vbatschelett May 27, 2011
    Thank you so very much. Will try the solutions you suggested as soon as I can as leaving to go out of town for short time. Right now the machine is turned off at the breaker box.
  • Fisher and P... Master
  • 19,396 Answers
Hi.
If the machine gets hot near to the base even when cycle is off, that usually means that the igniter and flame is coming on, probably because of a contact or because of a defective control board.
If the problem instead is at one side, far from burner (that is what I understood), then there is a short circuit that is causing the heath.
In both situations the dryer must be taken apart. If heat comes from the burner, there may be also lint making things worse. Here a diagram of the base with heater.
Here all parts and diagrams for this appliance.
Posted on May 25, 2011
  • Ginko
    Ginko May 27, 2011
    Hi.
    OK, please let us know how it goes.
    Regards.
    Ginko
Fisher and Paykel Active Smart fresh food compartment indicator is blinking continuously
the model number you have provided is not enough detail to depict which product you have. The model number you have provided pertains to so many different models, as many start with that. Perhaps providing the product ID would certainly help those who are knowledgable to give the required answer.
E522BR - 519L bottom mount with hinge on right. Not knowing what active smart version it is, as the display could be at the rear of the interior, on the frotn right hand side or on a display panel on the door
Sep 22, 2016 | Fisher and Paykel Active Smart® E522BR...
Fisher paykel troubleshooting
place your hands on the drum and push it backwards . the door will open when it comes around .
Jul 19, 2014 | Fisher and Paykel DEGX2 Dryer
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Jun 26, 2010 | Fisher and Paykel DEGX1 Electric Dryer
The bottom drawer is leaking
replace the pressure switch to stop the flow of water that is the cause of overflowing
Jun 04, 2010 | Fisher and Paykel DD605FD Stainless Steel...
In the fridge the setting panel green lights keep flashing fisher paykel
if you leave the door open too long it will flash a warning
close the door and make sure it is tight .
if this doesnt work , just unplug the fridge and plug back in aftera couple of seconds, this will reset the unit and should solve your flashing problem
Oct 03, 2009 | Fisher and Paykel E522BRXFD Stainless...
Dryer takes MUCH longer to dry clothes than it should
Is the hose crunched down at all in the back
(vent hose)
Feb 09, 2009 | Fisher and Paykel Dryers
Fisher and paykel dryer
hi
is the filter clean and is there air coming out of dryer if all tis is ok it could be heating element or timer
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Fisher and Paykel SmartLoad DG62T27G Dryer Logo
59 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
