Question about Nitro BMW-482 Car Audio Amplifier
My Amplifier keeps blowing fuses.
I took out my subs in December and left the amp and wiring as is. Two days ago I went to put my subs back in and the amp would not turn on. There was a blown fuse. I replaced the fuse but the amp blew the new one in two seconds.
I have, since then, taken the amp out of the car, hooked up brand new wires directly to the battery (positive battery terminal to positive input, amp ground to the negative battery terminal), ran a new remote wire and removed all other inputs and outputs from the amp (ie. No RCA inputs from the deck and no speaker load or wires to the subs). It is now an amp with three wires. A power, a remote, and a ground.
The amp STILL blows fuses.
I have taken it apart today. I'm definitely not an electrical engineer; although I wish I knew one. I am looking to see if anything appears out of the ordinary - nothing does. All components look pristine, in tact, and well maintained. There is a circular donut with black, red, and copper coloured wires wrapped around it (all those wires are copper - about 18-20 gauge) I don't know what this is or how to check if it is the problem.
There is a coil with a thick black stick inside of it about an inch long. I don't know what this is, what it does, or how to test if it is working.
Basically, my question is, with this set of symptoms, can anyone come up with a reasonable diagnosis? If the amp is blown, that's fine, but it worked when I uninstalled the speakers in December. So, what could have possibly happened since then to blow the amp? There was no load on it.
Anyway, thanks in advance for the help!
JRG
Additional Details 2 minutes ago Model is:
BMW-482 2Ch MOSFET Bridgeable Amplifier
1000W peak
Serial No. 100420199
It turns on for two seconds and seems to be "working" until the fuse blows. Originally when the subs were still connected, it gave the "puh" sound when the power first turns on. This was normal for the three years that I had the amp running perfectly.
I didn't push it to its max either. I never turned it up very loud.
  • jgilchrist Aug 16, 2008
    Thank You! I have located two transistors that read near zero ohms. I am not sure if I am taking correct readings since there are three metal tabs connecting each one to the board.
    I will try to replace these. Is there any way to find identical transistors?
    If this turns out to be the problem, then I am in your debt.
    JRG
  • 631 Answers
It probably has shorted output transistors.If it's like many of the Asian amplifiers, the outputs will be larger than the rest of the devices clamped to the heatsink. If you measure the resistance between the legs of any individual output transistor and read anything near 0 ohms, the transistor or one in parallel with it is likely shorted and will need to be replaced. You'd have to remove it from the board for definitive testing.
The donut is a power transformer. The coil with the black stick is an inductor.
The following page will help acquaint you with the components inside the amplifier.
Amplifier Repair Primer
Posted on Aug 15, 2008
  • Perry Babin Aug 16, 2008
    What are the numbers on the face of the transistors?
    If there are 8 of the large transistors in the amp, you may have only one shorted. You'd have to pull them to know for sure.
    Before you do any testing, carefully read the information in the yellow table on the page that I posted.
    Let me know if you have any other questions.
I have a 2007 Honda Civic 2 door bought the car found the legacy LA 960 in the trunk worked great for 1 year took on a 500 mile ride and woofer gave out. Took to a repair shop they said fuse of 20 amps...
1. Stop going to this shop.
A fuse that keeps blowing is a sign of a problem. You never replace a fuse with one of a higher amperage because the idea is the fuse is suppose to blow before the the wires melt and catch on fire. The reason it stopped working and the fuse didn't blow is probably be cause the wire did melt someplace and you are lucky the car didn't burn. If it did burn and the insurance company found the 40 amp fuse, they would probably have refused to pay.
The idea that a repair shop would do this tells me that they don't know what they are doing. Read this
FUSES
Oct 18, 2013 | Legacy Audio LA960 Car Audio Amplifier
I have a rockford fosgate ounch 325.1 (2004). I recently helped my parents move and took the sub and its sealed enclosure out of my 1994 Ford Explorer. The sub and amp worked until the move. After I...
it sounds like you have a short someplace. also, if you have a multimeter, check the voltage coming out of the speaker terminals of the amplifier. if the voltage is higher than 4 or 5 volts, the amp is probably bad.
Jan 10, 2011 | Car Audio & Video
No power to amp.....all wire connected properly
is protection light coming on when sub is connected? some radios have weak remote that blow out easy..check power on it if power is making it to amp..if its an ANL fuse they can look good but be bad.
Jun 08, 2010 | Sony XM-1502SX Car Audio Amplifier
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Amp keeps blowin the two 30amp fuses on the amp.
Make sure that the speaker wires are wired correct at both the amp and the speakers......otherwise it sounds like the typical death of a power acoustik amp (great amps, but prone to a premature death)
Mar 29, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Fusion car amp problem
The amplifier likely has shorted output transistors. Going to a higher rated could easily have caused more significant damage.
Jul 27, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
No sound
good day, check your spkr impedance, if 4oms use a posive spkr dividing network. if stills blows up replace a higher amperage of your fuse. ex.4A raise it up to 5A. the your amps consume higier current if more spkr wattage.
May 29, 2008 | Kenwood KAC-5203 Car Audio Amplifier
Protection light keeps coming on
Check the wiring between the sub and the amplifier. That's seems to be the only thing left that could cause a problem. If it's shorted to ground or pinched so the conductors are shorted together, it could cause the symptoms you listed.
Oct 01, 2007 | Sony XM-2002GTR Car Audio Amplifier
Nitro BMW-482 Car Audio Amplifier Logo
109 people viewed this question
Top Nitro Car Audio & Video Experts
ravie__s
Level 1 Expert
Mark Skinner
Are you a Nitro Car Audio and Video Expert? Answer questions, earn points and help others
