Question about Panasonic KX-TA62470-2 (KXTA624702) Expansion Module
Hi, all of my KX-T7736 phones connected to KX-TA624 started to get lots of static noise and cannot receiveincoming calls> CO lines are clean. What should I check to fix the problem? Where can I get a manual to reprogram the box if I have to to fix the problem?
    New Friend:
Psu problem the 7736 run a few more milliamps then normal as they have a larger display plus its powered all the time,and the psu cant cope....hope this helps
Posted on Jan 21, 2013
No access to outside lines from one jack
Hi, What you can try is check the plug connection. If they are bent or broken. Replace the cable to and from the phone. If that is OK then you know the phone is the problem. Take it to be repaired.
Jan 20, 2014 | Panasonic KX-T7730 Corded Phone
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
RE : Panasonic KX-TG6461 I installed this phone
thats an hardware fail , you need a service shop to fix it
Sep 13, 2013 | Panasonic KX-TG6461ET DECT Corded and...
Unable to receive calls on Panasonic KX T624
There is a reset code for each handset which I believe is 790,
Jul 14, 2012 | Panasonic KX-TA1232/KX-TA624 phone
We want to transfer a call to a phone number (external party). System programming is required. Can you help me? Thanks, Gina
Panasonic KX t7730 call forwarding function to external party:
If you are using the Kx-TA624 pbx (TES 824 models) system, program your phone unit (t7730) as follows: lifet handset, press FWD/DND button, press 3, then the outside line access code, then phone number, then #, then return handset.
If you are using the kx-ta1232 (higher models) of pbx system (usually with 9 or more CO lines cabable, use the following command:
lift handset, press FWD/DND button, press 6, then the outside line access code, then telehone number, then # then return handset to cradle.
Jun 11, 2009 | Panasonic KX-T7730 Corded Phone
KX-TA824 Select idle CO line
No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
Carl
Jan 24, 2009 | Panasonic KX-TA824PK Phone
Programming CO Pick Up Order
It can be done. Need to know the model of the phone system
Jan 21, 2009 | Panasonic KX-T7736 Corded Phone (KXT7736)
How to drop 1 party from a 3-way conference call on KX-T7736
I believe you push the CO button, of the call you want to keep! (you have to remember which call is which!!
Dec 05, 2008 | Panasonic KX-T7736 Corded Phone (KXT7736)
Panasonic KX-TA62470-2 (KXTA624702) Expansion Module Logo
61 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
