Question about Kirby G4 Bagged Upright Vacuum
How to how do i put the bag on properly so it will turn on the saftey switch
  • 357 Answers
Hi redd79!
All you need to do is to lube up the hole where the bag goes on with either hand lotion or dishwashing liquid. Put the bag on and twist it up against the side of the kirby until it engages copmpletely. If this doesn't work, you may have a bad switch.
Just in case...
http://reviews.ebay.com/REPLACING-THE-POWER-SWITCH-ON-ANY-KIRBY-G-SERIES-VACUUM_W0QQugidZ10000000003752018
Hope I helped!
Marci
Posted on Aug 28, 2008
Put in new bag but as soon as we turn vacuum on motor stops red light comes(bag full)
make sure the bag is installed properly and the bag door is making contact with the small switch by the bag.
Jan 03, 2010 | Electrolux Guardian Bagged Canister Vacuum
My Kirby G4 won't turn on. Everything is engaged as I normally do it, nothing is wrong with my power outlet, changed my hepa bag to a brand new one...
It could be a few different things. First make sure the emptor tank on the side of the unit is pushed all the way closest to the unit. ck to see if light comes on (that will tell you if you have power to the unit.) if so It is an internal problem. Or it might be, what is called the power foot switch. It's kinda of like the brain for the kirby there are 3 saftey switches built into it. they must all be working at the same time for the unit to power. If need be take it to a vacuum repair shop one with free estimates. this way they can diog. the problem and give you a repair cost, if need be. Hope this helps.
Nov 13, 2009 | Kirby G4 Bagged Upright Vacuum
Power nozzle N137A
Call 1-800-948-1358 ask for Josh or Buck.
Apr 14, 2009 | Electrolux Guardian Bagged Canister Vacuum
I have a kirby sentria and after I shampoo'd the carpets I put it back together to be a regular vacuum and now it wont turn on. Any ideas what could be wrong?
The only thing I can think of is the brush head is not on properly.If the head is not aligned right,then the saftey switch wont be activated.Otherwise,I'd say the saftey switch or power switch.Did you make sure not to run over the cord?
Dec 15, 2008 | Vacuums
Upholstry mytstery
there are two saftey switches. one on the air input, and one on the air output. someting has to be covering each. USE the SAFTEY CUP on the input and the Hose on the OUTPUT. does that answer your questions 4n4l <unt?
Jul 29, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4D vacuum
Could be the a/c cord, a problem with the noozle not pushing the saftey switch, the bag emptor(bottom of outer bag) isn't on the of the way and not engaging the other safety switch. The other is a problem with the motor.
Jun 28, 2008 | Kirby G4 Bagged Upright Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Jun 19, 2008 | Electrolux Epic 6500 Vacuum
Full bag system works properly, but doesn't reset easily
Either there is something wrong with your switch. Which it doesnt sound like it. Take it to your dealer or call another one it sounds like the control valve needs to be replaced. I am a dealer 1-866-966-9350.
Jun 19, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Kirby G4 Bagged Upright Vacuum Logo
55 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
