Question about Husqvarna Designer I
Bobbin Thread cutter no longer works
I took the bobbin case out of my machine to clean the lint out.. I think I dislodged the cutter blade in the process as there was a small blade lose in the bottom of the case. The machine no longer pulls the thread to the back of the fabric or cuts it off.
What have I done wrong?
Wendy
  • 2 more comments
  • maribe123 Sep 07, 2008
    The same think happened to me, so I really hope someone can help!
  • Annika080 Oct 13, 2008
    Well, I was sewing like crazy and broke the needle and the same thing happened to me. I have no idea how it looked before the disaster so I really need some help in this matter.
    Regards
    Annika
  • kbailey590 Oct 25, 2008
    Any help with this yet? I also am having the same problem
  • wendyowden Oct 27, 2008
    This is how I fixed it.... it wasn't beyond the wit of woman - but I was very slow to get it as I was worried about how much it would cost to get it wrong! I am sure this is fraught with danger and these are very expensive machines - just keep them clean with the little brush they provide!
    a) the cutter blade I had found was a spare - it is housed in the front edge of the bobbin case - just to the left of the little hook/thread guide that you pass the thread through when setting a fresh bobbin. There are a couple of little slots - the blade slots in safely 'till you need it. When it is all back in place it is hidden inside the machine parallel to the front edge.. you wouldn't even know it was there!
    b) before I found that I wasted a lot of time on an unnecessary and nearly expensive detour.
    DON'T do this......
    I took off the plastic cover to the left of the bobbin case. This is where the thread cutter sits. I took the cutter out, cleaned it and set it back again... incorrectly.
    It took me many attempts to get the thread cutter reseated properly (in the process I lost a tiny circlip from the back of the mechanism which I should never have touched.. a new one would have been £50 with delivery), fortunately, with patience and an industrial magnet I found it and, eventually, I got it all back together.
    If you have done this... Don't touch the little gears or the circlip - they are not the problem!
    The blade sits in the blade holder (sticking out far enough to break the thread when drawn across it)
    The blade holder rides in the little rail on your side of the cutter arm
    The leg of the blade holder sits within the little square ridge thereby restricting its movement
    The two pins from the gear mechanism sit in the little slots on the top of the cutter arm and push it across towards the bobbin case.
    If you have been as daft as I was - and taken it apart - I can send a photo... but if you don't take the cover off and mess about with it - it won't go wrong!
I have a designer SE, I ran across this site and found it very helpful. This person is a retired machine repair person and has a wealth of knowlege. <http://www.sewmuch4retirement.com/tips.html> from what I understand the blade needs to be cleaned as part of the Maintenance, it also can be replaced.
Take a look at this site, perhaps it will help
Far Away Grandma
Posted on Oct 26, 2008
My machine will not sew. New not used but a few years old. once thread goes down to bobbin it locks and you can hear the clutch disengage. without thread you can run the needle at full speed then it
There may be a small bit of thread or lint caught somewhere in the bobbin case or bobbin holder. Brush lint away from the feed dog area, being careful not to brush lint into the workings of your machine. If you have the manual, look up how to clean lint from the bobbin. If you don't have the manual, try just taking the hook out, if possible. Run a clean toothpick around the housing and then use a clean small brush to brush out any lint or thread pieces. Put one drop of sewing machine oil on the hook of the bobbin housing. Then use a thread to "floss" your bobbin case. Run a thread through the slot and wiggle back and forth to loosen any caught thread bits. Good luck. ps If this doesn't work, repeat. Sometimes after you turn the hand wheel a bit, another piece of thread or lint will work loose and can be cleaned.
Dec 06, 2014 | Sewing Machines
Bobbin thread not cutting
With the bobbin case out of the machine, touch the cutter button. Do you see the cutter arm move from left to right and then back left. If not the cutter arm is out of place. If it does it is something else.
I usually check two things:
1 - your cutter blade might be missing or dull and needs to be replaced. I would not recommend doing this yourself unless you are very good.
2 - many times there is lint or loose threads around the cutter in the area to the left of the needle plate that needs to be cleaned out. You can remove the cover to this area by first removing the needle plate and bobbin case. Then the cover is accessible to pop off by sliding the tip of a small screw driver under the cover at the bottom right corner of the cover. There should be a little opening. Carefully pop the cover off but be careful that the blade mechanism does not come off too. With your finger carefully hold the silver metal blade area steady and pick out the loose threads/lint from around the copper looking metal part. There is velcrow on the tip of the copper metal part so be sure that you don't remove that too. That's what holds the thread for the blade to cut it. If velcrow is missing, or the silver metal part is out of place that could be the problem also.
I recommend that any repairs/service be done by an authorized Viking dealer. You can find a local dealer by checking the Viking website at http://www.husqvarnaviking.com/us and going to the Locate a Dealer link.
Good luck
May 13, 2014 | Husqvarna Designer I
I have a Pfaff grand Quilter and my top thread is not catching the bobbin thread. When it does the stitches skips. Can anyone help!?
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Jul 15, 2011 | Sewing Machines
My singer 4423 is having an issue. the thread from the bobbin is not looping with the thread by the needle. If I feed some material through the needle goes up and down like it is suppossed to but there is...
Hello
Have you replaced the needle? Sometimes something that simple will solve the problem.
To solve the problem i put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
some machines can get "out of time"...the needle and the bobbin thread don't arrive at the right place at the same time.In this case you need to take your machine to a repair shop for re-timing
Jul 14, 2011 | Singer 4423 Sewing Machine
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Oct 28, 2008 | Husqvarna Designer I
Janome MemoryCraft 6500P auto cutter problem
I have never had this problem on any of the machines i have repaired.
What happens if you press the needle up/down button?
Feb 25, 2008 | Sewing Machines
Sewing Machines Logo
482 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
