Question about JVC TH-A55 System
I cant seem to get rid of the wide screen borders
    Brigadier General:
  • 8,546 Answers
The receiver's part of this is in the Picture Menu. Read the section on page 53.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/search?q=JVC+TH-A55
Your TV may also have a part in it. Read the manual.
Posted on May 25, 2011
DVD leaves 1/2 border on left side of screen in wide mode. what is Cinema aspect ratio for? Distorts Adjustment?
you have to adjust with the dvd players settings.
google your make and model #, manual and manual should show.
press the helpful button and follow me on fixya for more tips
Feb 01, 2016 | Proscan Televison & Video
How do I get rid of grey borders on sides of screen?
Grey border comes on the screen may be because or the LCD panel is faulty or the t cone baord is bad. as you didnt mentioed anything about the brand and model number its not possible an exact solution. Here added link with the help which you will be able to solve the issue .
http://electro-medical.blogspot.in/2015/11/lcd-tv-t-con-board-troubleshooting.html
Nov 06, 2015 | Televison & Video
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can i get rid of the borders on top and below the picture
In most cases you can remove those borders, but it depends on what source you are feeding to your tv and they way it's set up.
Here are a couple things you can try.
Look on your tv remote and press a button labeled either tv ratio, aspect, or wide. Im not sure exactly what it may be on your specific remote. Press that until you see the borders disappear. This will be called Full or wide zoom, but full is going to look the best.
If you cannot find the wide button on your tv, check the remote for your sat, dvd, or whatever source your feeding and go into the setup and change the aspect ratio to full. If you can provide the specific source your using, i might be able to provide some better detailed information
Good luck
Jan 07, 2011 | Toshiba 27AF42 27" TV
Black border with some channels
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
Apr 07, 2010 | Memorex MVDT2002 20" TV
I want to change the picture size to wide screen and when i do the picture goes off the screen and i cant seem to get it just right please help me :)
What type of connection are you using? Is it a VGA cable? You TV should have a function called Auto Adjust. It will adjust the picture to the borders automatically. Check if you have that. If not, your TV should at least have options to adjust the picture position yourself. Just like a computer monitor screen where there are buttons on it to adjust the picture.
If your TV is a Vizio, I can guarantee what I said, I own one.
Apr 02, 2010 | Samsung LN-T4665F 46 in. LCD Television
Picture doesn't fit screen on Hitachi Plasma TV
I think that is just how the settings are applied in wide screen mode a little over sized
Oct 28, 2017 | Hitachi Televison & Video
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
Dvds
this is the dvds themselfs some are recorded in full screen mode and some are in wide screen mode (the ones with the borders
Oct 30, 2008 | Philips DVP5990 DVD Player
LCD Television Proview RX326
No better description then a picture! Can You post a few?
Jul 07, 2017 | LG 42LP1D 42 in. LCD HDTV
JVC TH-A55 System Logo
56 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
