Question about Symphonic WF803 DVD Player/VCR
My dvd/vhs player won't turn on. All I know is that it's not the socket.
  • 1 more comment
  • swimmingdolp May 25, 2011
    totally dead
    totally dead
  • swimmingdolp May 26, 2011
    For some reason it started working again, even though I didn't do anything.
  • 2,098 Answers
May I know if the unit has a standby led light or totally dead set?
Jdvillanueva
Posted on May 25, 2011
  • Jdvillanueva
    Jdvillanueva May 25, 2011
    If your unit is totally dead set, the problem is in the power supply board. Check first if the AC power is coming to this board. Check also the internal fuse continuity using a multimeter.
  • Jdvillanueva
    Jdvillanueva May 26, 2011
    Intermittent symptoms may caused by bad solder joints(cracked,dried,cold solder) in the power supply section. Loose connection from cable connector is another factor, you must pull-out the connectors from the power supply board and in the main board and then re-insert and ensure the connections. Check also the power cord for internal open wire. This was caused by frequent pulling and bending. You may wiggle the cord while in testing to see if it will react. Faulty electrolytic capacitor in the output of the power supply section will do the same symptoms. There are few of it in this board, if you can't test it using the multimeter, you may replaced all with same capacitance and working voltage which is printed on its body itself.
I have a sanyo dvd/vhs player and when you push the eject button to eject the dvd player it won't open. Help!
If you take off the top cover you might find that a drive belt that moves the tray is either off or broken. They are cheap to replace you just need to measure the diameter in MM and then enter "drive belt XXmm" into Google go for the nearest size to your measurement.
Jan 18, 2013 | Panasonic DVD-A110 DVD Player
Recorded dvd from my toshiba dvr620ku won't play on other dvd players
it could be the video format from the recorded dvd's not compatible in the dvd player that you have been used.
Aug 03, 2012 | Televison & Video
Put vhs in tv, now it won't switch back to tv
see the following step:
1) clean with VHS tape clean the inside componets, rollers, sensor,idler wheel
2) inspect any belt worn or broken.
3)clean with cotton pads, any parts with small amount of alcohol isoprophilic.
4) clean any sensors electric inside very well, and tight connector.normally when some sensor NOT switch back to turn TV.
God bless you
Jul 20, 2012 | RCA 20F610TD TruFlat TV/DVD
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
My toshiba DVD/VHS combi won't turn on and yes it
The power supply regulator section, or main ON/Off switch should be checked.
Jun 05, 2012 | Toshiba Televison & Video
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
VHS tape won't eject
Hello
Check for any borken drive belt in the mechanism.
Feb 13, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have copied a vhs to dvd but dvd won't play on other dvd players
DVD+R is a Sony format, so it may not play in the more common -R format players. Are you finalizing the DVD's if not they will only play on the deck that recorded them
Jan 25, 2012 | NEC Televison & Video
I have a Toshiba DVD/VCR combo and I want to know if i can record a VHS onto a blank DVD disc ?
It all depends on the model of DVD/VCR Combo and what VHS you want to copy.
Pre Recorded VHS are copyright protected so the system won't let you copy them.
May 29, 2011 | Toshiba Televison & Video
Symphonic WF803 DVD Player/VCR Logo
167 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
