The Unit is maybe 2-3 years old and it stops and starts interchanging between the fan and the heater symbols. Don't know why. It is a Pyrox Vulcan gas wall unit.
    Master:
  • 403 Answers
Replace the t-stat
Posted on May 25, 2011
The heaters instructions say to open the heater, but i don't know how.
1) For real?
How can we answer the question without model number, brand and type water heater?
Is this a boiler? Or tank-type heater. Is the thing 2 years old or 12 years old.
2) Look on label on side of tank. Include all information shown on label.
3) Attach a photo so we can see the problem more clearly.
4) Call service technician or plumber since this is a gas appliance.
Dec 31, 2012 | Rheem Water Heaters
My Acer Aspire 5517 keeps shutting off...
1. Check if the air duct inlet and outlet are free and free of dust.
2. If needed, clean it with a hard brush and vacuum cleaner.
3. Check if the fan is rotating, if not replace the fan unit.
4. Check if the fan is clean of dust, if so clean it.
Nov 16, 2011 | Computers & Internet
Our air stopped working and the thermostat inside the house is stuck digitally with a snowflake symbol,the hold symbol is on, everything is locked up..white rogers # 1f78 thermostat. a/c unit 4years old,
High, the 1f78 WR stat is the problem if it does not respond to any changes. I believe this stat has batteries, so you may just try to change them out. If not, go to any hardware store, Home Depot carries Honeywell stats that will work. I don't know if your unit is a heat pump, or not, if it is gas fired for heat, then it will take just a regular 5 day 2 day thermostat.They are easy to install, if not a heat pump, it will have a R for red which is the 24 volt hot, W or white for heat, G or green for fan, and either a Yellow for cooling, but blue is sometimes used. The stat will be marked with a Y on it. A heat pump has many more terminals, but the stat you have i am sure is just a gas/electric unit.If it does respond to all of your settings, and the unit will not start, you may have a problem out doors. Check all of your breakers to make sure they are not tripped. Please keep me posted.
Shastalaker7
A/C, & Heating Contractor
Aug 08, 2011 | Heating & Cooling
I have a very old floor funace. Peobably around 45 years old. There's know fan, just induction gas heat chambers with a grate on top. The unit stopped working when the HVAC guy changed the Thermostat...
He needs to put the old stat back on...... The old stat is a Millvolt stat and the new Digital ones won't work. And I don't know if they make a digital for Millvolt.... The old floor furnaces used a power pile like a oversize thermocouple for the power to operate the gas valve.
Jul 22, 2011 | Montgomery Ward (223600UP) Heater
My carrier 38CKC (60) is blowing hot air. The fan seems to be running fine. Is it the condenser coil, or just needs freon? How do I know? The unit is about 8 years old and never been serviced (I know...I...
Assuming the outdoor unit is running, make sure the fan motor on top is turning and the compressor is running. They both must operate for the unit to function.
The easiest and most common problems:
1. Condenser coil is stopped up with dirt. The condenser coil is the radiator looking coil that wraps around nearly the whole outdoor unit. It can be washed out with water and a sprayer, just make sure you don't bend the aluminum fins and disconnect power before washing it out.
2. Low on refrigerant. If you don't have guages you can't check the refrigerant on your own. If the fan and compressor are running , feel the bigger copper line coming from the outdoor unit going into the furnace. It should be cold. If not you can either be low on refrigerant or the compressor valves are weak.
Hope this helps. If the unit is not running outside, repost and I will try to diagnose differently.
Jun 16, 2011 | Heating & Cooling
Model # bx2255w Amana Refridgerator bottom freezer works but refridge isn't cooling any more. Is it time to retire our approx 15 year old fridge or is there an easy fix?
If you have high humidity or the door gets opened a lot, the evaporator coil may need a good defrosting. There are defrosting devices in the unit like the timer, heating coils, thermostats that could be bad. There should also be a small fan in the freezer that transfers the air to the refrigerator section. If that's not spinning only the freezer will work.
If you find the fan and it's working you can do a thorough manual defrost by removing the food, unplugging the unit and letting it set for a day with the doors wide open. Have some big towels handy :)
After a day, plug it in and see what it does (don't add food, yet). If it cools down then you will know that the compressor is still good and it's worthwhile to fix.
Easy fixes: Timer and fan.
Moderate fix (cheap part - more labor) - Defrost thermosat
Pain in the **** fix: Defrost heaters.
Ed
May 22, 2011 | Amana Refrigerators
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Require fan for pyrox lpg radiant gas heater unit approx 4 years old
THANK YOU FOR THE REPLY
NOT MUCH OF A PROBLEM WILL CONTACT YOU IF WE NEED TO FOLLOW UP.
Aug 19, 2008 | Heating & Cooling
Heating & Cooling Logo
342 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
