Boot stops,then blue screen occurs, repeat itself on the star
  • 639 Answers
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications.
right click on each application and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Posted on May 25, 2011
  • 84 Answers
Your operating system installation has been corrupted. You need to restore youir operating (OS) if you saved a restore point. If that does not work you need to reinstall the OS.
I hope that helped you.
RThanks for using fixya.
Computer went to blue screen what can i do this could a hacker or adware virus what can do
Most times a blue screen is a driver issue. If you've recently installed new software, boot to safe mode, remove that software and see if the problem goes away. Sometimes, overheating can case a blue screen too so check to see fans in your machine are working and the PC isn't overheating. Lastly, get the error message and search the internet for a solution. If you can boot to safe mode without the blue screen, it's most likely a driver issue.
Apr 30, 2014 | Office Equipment & Supplies
Blue screen occuring and the laptop restarts
maybe the problem of your laptop was the memory ram that was built in... or the hard drive i think...
Aug 11, 2012 | Dell Computers & Internet
The laptop stays on for few minutes and then it turns itself off but before it does that, it shows a large blue scree and some large white text, the text flicks a little but fast to the point where I can...
First of all Turn of your laptop.
Now this time when you turn on your laptop start tapping F8 Key on you keyboard when you Toshiba logo. Tap F8 key for at least 5-6 times.
You will get a Windows Advance Option Menu. You will see lot of options over their written in white text. Your mouse will not work on this screen. Use UP and DOWN arrow keys on you keyboard and highlight Last known good configuration. Once highlighted press enter on it. See if you computer boots. If it boots try doing a restore.
If it doesn't boot.
Turn off your computer and then turn on your computer. On Toshiba Logo screen tap F8 key once again and go to windows advanced option menu screen once again and this time hightlight Disable automatic restart on system failure. Now when you see Blue screen coming up on your computer once again your computer won't restart. Now you can write down the information to trace out the blue screen that is occurring on your computer. Write down the Error code which will be in form of STOP 0x000000XX, you find this error code somewhere at the bottom of the blue screen.
Once you get the reply here, we will see what we can do.
Jun 21, 2011 | Toshiba Tecra M2V-S310 Notebook
I bought my wife this laptop (emachines G640)only a few weeks ago we've had a few issues at start up when it goes to the blue screen and the the screen where it says there was an issue and to start...
The stop error screen or bug check screen commonly called the blue screen of death (also known as a BSoD, bluescreen, or "blue screen of doom.
In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
Often, if you're lucky, the problem will resolve itself with a simple reboot and you may never have to worry about it again. More typically though, the BSOD is a harbinger of trouble and you may find yourself faced with another and another until you throw up your hands in frustration... but all is not lost.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This is if you are able to boot into safe mode (Press and hold the F8 key during boot up). This will ensure that all driver bugs are fixed and that all hardware has the correct driver. If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name. There is a neat program on the net that can fix this problem, it's called DriverFinder, you can get it here.
If this doesn't work or you can't think or find the corrupt driver you could use System Restore (If it is enabled) to go back to a time where you didn't get the error. To use the system restore utility, go to 'start/all programs/accessories/system tools/system restore.
Sometimes though the blue Screen of death can be caused by faulty or loose rame cards. Check that your RAM modules are inserted correctly and arn't clogged with dust.
Feb 02, 2011 | Computers & Internet
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
Stop error screen
If you have installed a new hardware or software, it may be conflicting with the installed program there by causing your system to dump it time the conflict occurs. You have to boot the system to safe mode and uninstall the new software or remove the new hardware and restart the system. Your system is supposed the boot okay.
May 26, 2010 | ASUS P4S800D-X Motherboard
My Acer Aspire 4720Z does not boot anymore it shows a blue screen which sends me to launch startup repair. it does this repeatedly. Please help.
If you get a blue screen that usually means windows has a problem but the laptop itself is fine. You may need to reinstall or restore windows and it should be fine. Annoying but fine.
Mar 23, 2010 | Acer Aspire 4720 Notebook
Error Message while booting with blue screen
Basically this occurs by virus hit.. Now better install new operating system and never download cracks or keygens from any sites, most of them will contain virus which causes this.. and note while using pen drives too hold shift key when it is being inserted, this prevents automatic execution of virus.
Dec 28, 2009 | Microsoft Windows XP Home Edition
Try's to boot up, but goes to small blue screen
When your computer hardware appears to power up okay, but the Windows XP operating system won't boot properly, you have to begin a troubleshooting expedition that includes getting into the operating system, determining the problem, and then fixing it. To help you get started on this expedition, here are 10 things you can do when Windows XP won't boot.
#1: Use a Windows startup disk
#2: Use Last Known Good Configuration
#3: Use System Restore
#4: Use Recovery Console
#5: Fix a corrupt Boot.ini
#6: Fix a corrupt partition boot sector
#7: Fix a corrupt master boot record
#8: Disable automatic restart
#9: Restore from a backup
pls 4 stars .... :-)
Nov 29, 2009 | Sony VAIO VGN-S150 Notebook
I have this Hp pavilion dv2000, system get started then asks me to start with normal start or safe mode, whatever I click next screen shows windows logo and then it stops after a flash of blue screen with...
for that you need recovery disk or windows xp bootable disk.
For that put that disk in rom.Then when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option set first boot device as your cd or dvd rom then save settings and exit.
Then it boot with disk then follow the procedure then enter in recovery console then type in prompt "chkdsk /r"
then press "y"
then it recovers error on harddisk.
Then check.
If still face same issue then you have to choose repair option so it fix windows.
This blue error comes when there is issue in bed indexing in harddisk.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
