I just purchased a Dell Inspiron i570 computer. I hooke my HP C3140 up to it. It shows as my default printer but the status shows as offline. How do I change it to online?
    Sergeant:
  • 147 Answers
My friend has told me this problem is coming because of connection problem ; so you should try to visit How Do Fix Dell Printer Say Offline Using Windows Laptop Fixotip and follow the instructions to fix the problem.
Posted on Sep 16, 2017
    Master:
  • 395 Answers
Offline means the printer is off. You should check printer to see if it is off, then turn it back on. If it is already on, check the cable (usually usb printer cable) to make sure the cable is securely plugged in to computer and and to printer. You might also need to reboot your Dell printer too. After all these, but printer still says offline, you might need to delete that printer in control panel, printers and faxes and reinstall again. If this is a case, you need to follow the printer installation correctly for it to work. Let me know if I can further help.
Thanks
Posted on May 25, 2011
Printer showing offline
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Jul 10, 2011 | HP DeskJet 6988 Printer
My HP officejet 4315 v All-in One is set as my default but the status shows offline, how do I turn the status to ready and to be able to print from the computer?
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Feb 06, 2011 | HP Officejet 4315 All-in-One Printer
The shared printer shows offline. The computer operating as it's printer server is Windows 7 as is the laptop attempting to send jobs to it through the homegroup share. Is this a printer problem or an OS...
check on the server if the shared printer is online. check also on the work station if the printer configured properly as shared. (try to check printer network communication)
Jan 14, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printer status always offline
go to your programs and select printer and faxes..rigth click your printer icon and select use this printer online..and if you want make this printer to be a default printer select also use this printer as default..
May 18, 2009 | HP DeskJet 3940 InkJet Photo Printer
Photosmart 2575 printer is offline - won't print
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Oct 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
Sep 02, 2008 | HP DeskJet F380 All-In-One Printer
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Jul 01, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
k24674
