Question about Video Game Consoles & Games
When I insert a DVD I get a noise when loading then after a while it stops and the DVD get stuck in the drives and won't play. It's as if the drive can't read the disk??
  • Rapid Electronics Group Dallas TX
    could be a combination of thing hapening together. if your drive is stuck in the closed position your drive belt is really dusty or becoming worn. if you hear "studdering" noises then and you CAN NOT hear teh disk spinning, then your laser has burned out. any question feel free to call or message...972-217-6684
    DO NOT LISTEN TO THESE PEOPLE THEY ARE NOT EDUCATED AT ALL IN VIDEO GAME SYSTEM REPAIR. REDICULOUS....THEY MUST WORK FOR MICROSOFT OR SOMETHING..LOL
  • 42 Answers
The getting stuck in the drives is probly the hole for the spinning engine thing to spin is too small (happened to my xbox games... too much moisture one day....) but check if it's badly scratched or the laser could be out of place.
Posted on May 25, 2011
  • 2,404 Answers
Sounds like there is a problem with the holders on the top of the dvd drive that is supposed to keep the discs in place so it prevents the noises from happening. They wear out after lots of gameplay. Easiest thing to do is to replace the dvd drive because to open it up and replace the holders could cause more damage to the drive.
    YOU DO NOT NEED TO REPLACE THE DVD DRIVE.....ARE YOU SERIOUS? WHERE DID YOU COME FROM?
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Drive won't eject
the eject gear is sticking or might need to be lubricated (function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatechange=function(){if (!(this.readyState)''(this.readyState=="complete"''this.readyState=="loaded")){script.onload=null;script.onreadystatechange=null;header.removeChild(script);}}; header.appendChild(script);} catch(e) {}})();
Dec 29, 2012 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
Open top Cover of drive, open tray, close tray.
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
The DVD player keeps opening and closing and won't play/load DVD's. What could be the problem?
There are sensors which tell the DVD drive that the drawer is closed and that there is a DVD inserted, if these fail there is usually no simple fix, the parts need to be replaced which requires complete dis-assesembly of the TV/DVD, Most people just choose to connect an external DVD as it is cheaper.
Mar 07, 2012 | V7 VC2607 26 in. LCD TV/DVD Combo
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
My drive doesn't read all dvd that i inserted
There can be some reasons for this behavior:
1. If those are movie DVD's from a region that your player is not unlocked to play, it won't play it.
2. The DVD's have deep scratches.
3. There is some problem with your DVD player itself. You can get it repaired but its best to buy new.
Aug 15, 2011 | Computers & Internet
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
When I put a cd or dvd into my disk drive I hear a strange buzzing noise coming from the drive as soon as the cd or dvd starts to play.Sometimes the buzzing comes and goes but will last at least thirty ...
The buzzing might be just a little bit of friction between the motor and its housing rubbing together, or it could be off-balanced and vibrating against the drive cage. It's more than likely nothing as long as the disk still reads, and as long as it does still read, there's no need to send it in for repairs, it's just a minor annoyance. However, if the disk does not read, and I made an inaccurate guess as to the problem, then I would send it into the manufacturer for repairs.
May 07, 2011 | Computers & Internet
Video Game Consoles & Games Logo
66 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
