Question about Gateway M-6843 Notebook
My laptops is a Gateway M-6846, and the problem is, dont turn on, the only way is with a charger battery then turn on, i change the jack adapter and the power button, and dont solve my problem... can you help me please... thank you
  • alex_campas May 25, 2011
    ok, the problem is, no charge the battery and dont turn on with ac adapter, the only way to turn it with a charged battery... can you tell me how to check the layers between the motherboard and the jack?
    Genius:
  • 1,570 Answers
HI
I might be the operating system is corrupted. Try to reinstall the operating system, using the Operating system installer CD and when it load. It means the problem is the corrupted operating system.
If not, we have to eliminate the cause of your problem.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on May 25, 2011
  • Benjamin Jr Singson May 25, 2011
    Hi
    The problem might be the jack socket is defective. As you mention, it didn't turn on when you replace the Power Charger. The cause would be defective jack socket. Did you shoulder correctly the when you replace the jack socket. Here is the link for the http://www.laptoprepair.co.uk/how-to-rep....
I have a Toshiba PSAF3U-0NR00V, every time i plug the charger to the laptop it goes off, but comes on without the charger, it would charge the laptop,when it's turned off but if i try turning it on...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 23, 2011 | Toshiba Satellite A205-S5804 Notebook
Computer wont turn on
Hello.
Hope this helps.
Aug 25, 2011 | Gateway Solo 1450 Notebook
My computer just stop now i want to turn it on it doesnt work ...my charger is still good because the indicator light burns but when i connect it to the laptop it stops burning the screen just went black...
Hello.
Hope this helps.
May 11, 2011 | Computers & Internet
I have a dell inspiron 10 and a couple months ago it stopped working out of know where i have never dropped it. the problem is the battery sometimes blinks even when the charger is plugged inside of it. I...
Hello.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty. Since you swapped the battery, the battery is is probably OK.
If no change, the power adapter is probably faulty and needs replacement. Try your cousin's power adapter to see if the problem goes away. If the problem goes away, replace your power adapter.
Hope this helps.
Apr 23, 2011 | Computers & Internet
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Gateway m-6846 don't turn on neither ac adapter nor battery
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
5.if you will get the same problem again means suspected issue with main board.
Nov 22, 2010 | Gateway M-6846 Notebook
WON'T CHARGE
If you have no power and the battery won't charge. There is a short in your DC jack socket. This problem is common among gateway computers. If you can solder, you might want to take the computer apart and put a new power jack in there. New power jacks costs $2. Otherwise, you should look for a new motherboard on ebay and buy it for a little over $100 and put it in yourself. Getting it professionally repaired can be very expensive and not worth it.
Sep 13, 2010 | Gateway M-6846 Notebook
Okay if my gateway m285 pc tablet wont turn on how do i know if its the charger or the battery itself?
just do a simple test. plug your charger in AC mains, at the jack end, insert a wire and then try to make instant contact with the jacket of the jack. you will see a brief spark. If spark is there, it means your adapter is good. rest you know that if charger is ok and still laptop is not working it means that there is something wrong with the power section inside the laptop. Even with a bad battary, if adapter is good, laptop will work, provided power section of the laptop should be ok.
cheers
Sep 04, 2010 | Gateway M285-E Notebook
Gateway MX8738 power adapter problem
Does the DC jack on the laptop wiggle or feel loose?
If that's the case then eventually the jack will go bad will have to be replaced. Most computer shops charger around 60-100 for the repair.
If it's the charger itself then just replace it with an ORIGINAL from eBay.
Hope this info helps and if you need more specifics just let me know.
--RescueTechLA
Nov 29, 2009 | Gateway MX8738 Notebook
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Gateway M-6843 Notebook Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
