Question about Ruud UPMC036 Air Conditioner
Am i being billed while fan continues to stay on
    Master:
  • 403 Answers
Yes
Posted on May 25, 2011
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
When I turn the ignition off my fan stays on most of the time. Is the fix just a new switch?
Failed Cooling Fan Module May Cause Fan to Run ...
repairpal.com > Problems > Mazda > MPV
When turning the ignition off, if it stays running, just flick the ignition back on, but no so far as to ... My fan stays on after I cut my car off and it drains my battery.
Oct 23, 2015 | 2004 Dodge Ram 2500
Why does my fan stay running for more then 90 minutes until the battery goes dead
Radiator fan runs continuously - volvoXC.com
www.volvoxc.com > Forum > The Vehicles > 2001-2007 XC70 (V70XC)
Jul 12, 2011 - 10 posts - ‎6 authors Hi, I have a problem with the radiator fan running continuously. ... According to Volvomechanic, when the pressure in the aircon gas goes ... 2002 xc70 cooling fan stays on
Jul 15, 2012
Blower Motor stays on.
Jan 15, 2011
fan after cutting off ignition?
Jul 25, 2004
More results from www.volvoxc.com
Oct 20, 2015 | Volvo S80 02 2002
Why won't the unit stay on?
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE.
May 17, 2014 | Samsung RF217ABBP Bottom Freezer French...
Fridgidaire/Electrolux dishwasher stuck knob
It definately sounds as though the motor in the timer assembly is dying, or the gears in the assembly are wearing down to the point that the gears can't turn the way they're supposed to. Replace the timer.
Apr 17, 2012 | Frigidaire Dishwashers
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Toshiba television
Is it a Toshiba or RCA? What's the model number?? When it "stays on..." do you get a picture and audio okay??? If you continue turning it back on does the lapse in time continue to get longer????
Bill
Nov 27, 2007 | RCA F27450 27" TV
Ruud UPMC036 Air Conditioner Logo
19 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
