Question about Kenmore Elite 45986 Front Load Washer
Dl F error. The door mechanism will not lock
I've read that I can remove the top panel and check the wiring. How do I remove the top panel?
  • 5,911 Answers
"Fdl" is a door latch error, just in case you haven't figured that out already. The following link explains how to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
To answer your question, yes, you should be able to check the wiring by removing the top panel. The top panel comes off by removing the three torx screws in the year of the washer that hold the top panel in place. With the screws removed, the panel will slide towards the back, then lift off. I hope this answers your question. If your require additional assistance, pease let me know.
Posted on Aug 15, 2008
Whirlpool Duet HT Washer flashes code F dL.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Door Lock Mechanism broken or removed from the Door
Check Door Lock/Switch Assembly
Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Mar 14, 2013 | Washing Machines
What is an error code of DL?
F/dL error - Door Lock Error
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
Good luck.
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The wash cycle stops before it finishes and reads either f-11 or dl. What can be done?
F11 Error
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Check The following things:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
F dl Error
Door Lock Error
Check the following things
Thank You
Sep 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't start, makes a clicking noise and than a code comes upF DL
Hi
Thanks for using FixYa. Error “dlf” or f dl means a door latch failure. This means that you’ll need to replace the door latch assembly however before doing that you can leave the washer unplugged for 30minutes so that it resets itself. In the meantime when it’s unplugged just inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. To remove the top panel just remove the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, and then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If after doing this still the issue is not resolved then unfortunately you have to get the door latch replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 29, 2010 | Kenmore Elite 45986 Front Load Washer
GHW94OOPWO....has been solid as a rock for 6 years.....Wont fill up tried to restart and got F flashing then dl flashing steve in sv
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you
Jul 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Thank you !!
Jul 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool duet GHW9100L washer door will not unlock and code comes up F dl, any idea's?
Ff dl (failure fault door lock)
Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
Potential Causes
The door lock may have to be removed and replaced to get past this failure.
Mar 18, 2010 | Washing Machines
My front load washer is flashing DL. It is a maytag but I do not know the model number. I bought it about 2 years ago. I have it in my apartment and I think that it is 24" in width.
Hi There
I'm sending you this to read and hope this get's you in the right direction.
Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Maytag MAH8700A Front Load Washer
Door lock
dl meand door lock. A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error. Potential Causes ? Door Lock Mechanism broken or removed from the Door ? Check Door Lock/Switch Assembly ? Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) ? Door Lock/Switch Assembly Failure Replace failed component.
Sep 22, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
53 people viewed this question
Ron Lankford
Archaeology
Archaeology
2mikecurtis
