Question about Brother HL3040CN Laser Printer
Brother HL-3040CN says it has paper jam inside, but it has been cleared and checked. Error won't go away, printer won't work...
    Brigadier General:
  • 3,917 Answers
I do understand that you have got the piece of paper removed from the printer. Even after this when its still showing the same error it's for sure that there is some more bits strangled inside. Please remove the toner and then check or clean the printer thoroughly. Also remove and straighten the papers that are there in the stack.
Hope you have the manual for the same to understand how to clean the printer. I am posting the manual for your reference:
http://www.retrevo.com/pdf/23576ci662/90/Paper+jams+and+how+to+clear+them#q=Brother+HL-3040CN
Posted on May 25, 2011
I have a Brother Printer HL-240D that gives me a constant paper jam inside indication even though the paper goes completely through the printer, and there is no actual paper jam. What switch causes the...
Have you tried shutting it down completely? Also, double check to see if the inside of the printer is completely clean. I had the paper jam indicator showing because there a small piece of paper stuck inside. Also, found a helpful manual for a similar printer, you can see it here - Brother HL-2240 manual
Sep 29, 2013 | Brother HL-2040 Laser Printer
Won't print. Alarm says it's out of paper, but that is not the case.
Hi
Turn it off and on.
Check through the paper paths and clear any paper jam.
Try disconnecting the printer.
Leave it for like 2 hours and then connect it again.
Feb 26, 2012 | Brother HL 1240 Printer
After paper jam cleared HL-2140- printer continues to flash error error error------- What is solution
Be sure the front door is closed and that the fuser door is closed. Also be sure none of the sensor flags are stuck down. Also try pressing the Go button to see if the error clears.
Jul 07, 2011 | Brother HL 2140 Laser Printer
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But...
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But this doesnt work?
Apr 20, 2011 | Brother HL3040CN Laser Printer
The alarm light is on and it won't print
Check the back of the printer. Open up the back door. There is a barely visible 2nd door which you need to open. Check to see if there is a paper jam behind this 2nd door. Often this is the problem and clearing this back paper jam will clear the red alarm light.
Nov 04, 2008 | Brother HL 1440 Laser Printer
Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Feb 10, 2008 | Brother HL 1440 Laser Printer
Brother HL3040CN Laser Printer Logo
634 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
