Question about Samsung Televison & Video
I have a Samsung LA26R71BDX LCD Television. It is 3.5 years old. On and off the picture freezes and then displays vertical coloured lines. I can still hear the audio.
  • Samsung Master
  • 2,098 Answers
This kind of symptoms indicated of internal board's malfunction. The affected boards are the sustain boards, control board, and power supply board. Plasma tv is the most hard working tv nowadays. Excessive heat build up causes the boards for malfunction.
First you must isolate the unit from loose connections because it will do same symptoms. Pull-out the cables connected from the said boards, inspect, re-insert and ensure its connections. If the symptoms still persist, check the boards for bad filter electrolytic capacitor. Faulty capacitor has a bulged/dome at the top and will produced an out-of-regulation in the supply voltage and will affect the performance of the boards feeds from it.
I have a Samsung LA26R71BDX - jdvillanueva_22.jpg<<<<(faulty electrolytic capacitor)
You may isolate also the faulty boards by touching its IC's, you will feel that the IC gone to excessive heat even a few minute of operation only.
This kind of symptoms is quite technical and needs an experienced tv technician to troubleshoot the unit if the simple fix didn't cure the problem.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a professional or sent it in.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 25, 2011
Panasonic LCD TV Modeel No: TX-26LXD8A has vertical coloured lines that change colour depending on the program/picture. It began with a vertical red line near the centre of the screen and now there is no...
Other than taking the television to a repair shop not much can be done. I recommend a new television. Excellent brands are Sony, and Samsung. Both brands are quality televisions. Best of all you can order them on Amazon.com for lower prices.
Jan 23, 2014 | Televison & Video
Left side of display has flickering vertical lines
Bad video driver chip for that location. Needs to be serviced.
Jan 14, 2014 | Samsung LN-S4051D 40 in. LCD Television
My ten year old sony plasma tv has vertical herring bone lines no picture just color lines. Is my picture tube gone.
If its 10 years old boards and or parts will likely not be available--average life on Plasma and LCD sets is 3-5 years.
I would retire it--recycle it and buy a new set.
May 16, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
I brought 3 samsung LCD from harmon house dubai now 3 LCD in india there is one LCD is complaint (comming center line and color change) i told your service center thrissur kerala india but their asking...
The central vertical line in the display is due to the damage caused in the LCD display due to impact..probably during shifting.As result of it the colour mixing fails.
The colour could also fail due to colur IC chips failure too...due to impact or voltage fluctuations.
You will find lot of Purple,& green in the display.
Get it serviced in a authorized center.
Sep 19, 2011 | Televison & Video
Faint vertical lines on my samsung lcd 1080
hi
this is the problem caused by 3 main issues
1.colour wheel
2.cathode ray tube
3.jungle ic on D-board
check it..//thank u
please rate it
Jul 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Open Questions:
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
