Question about Bosch Axxis+ WFR 2460 Front Load Washer
I replaced the hot water valve. Two days later, a whining noise appeared when hot water was flowing to the machine. Initially, when the water begins flowing through the hot water pipe and the water is still cool, everyting is fine. The whining noise starts a bit later, when the water pipe is hot. What else could be wrong? Could it be the other valve (cold water?) I noticed that the cold water valve has two water connections, one of which is connected to the hot water pipe.
  • 4 Answers
SOURCE: only hot water pipe going in
Don't know that particular make, but if there's only one water inlet available the machine should use its own electric heater. A "Wash Temp" setting switch should be available.
Posted on Jan 14, 2008
  • 1462 Answers
SOURCE: Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Posted on Sep 13, 2008
  • 13 Answers
SOURCE: Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Posted on Apr 11, 2009
  • 215 Answers
SOURCE: my bosch classixx 1200, my washing machine leaks
Remove top and check that they are your fill vaulves. Your hoses should be connected to them if so.If they are leaking on inside of machine when off then they need replacing.
Posted on Mar 15, 2010
  • 6277 Answers
SOURCE: just bought a new washer
You just need to collect the cold pipe- the washer does the heating itself for hot washes. It uses the water cold for rinses ;-0)
And for a manual-
you will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Posted on Feb 24, 2011
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
LG washer high pitch noise when water enters at beginning of cycle
Two possibilities: the water is coming in under pressure through a solenoid valve that is not fully open or the pressure pump is whining on its bearings.
Jan 22, 2013 | LG WT5170V 4.7 cu ft High Efficiency Top...
I have a 1988 Hotpoint top-load washing machine, Model # WLW 3500B. The water supply on the hot side appears to be constricted with very little flow. I checked the screen in the water supply hose and there...
Hi Eric,
Have you taken off the hose for the hot water at the back of the washer and then run it into a bucket to make sure the flow was good there?
If you have great flow there then the problem is in the washer...
If not then it is in your plumbing...you will need to track that down and fix it...
If it is in the washer then you probably have a problem with the fill valve or solenoid valve that opens to let the water in...they can either stick or get dirt lodged in them...either way replacement is probably the best option...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 07, 2011 | Hotpoint Washing Machines
We have an F&P top loading washing machine Model MW512, Product 92194-A. Problem: Poor water flow and noise from machine when filling tub for washing cycle. Initially occurred with hot water flow 12...
Depending on you lacality..IE Country, etc, you may be able to access the parts from a washing machine parts supplier.. Check the yellow/pink pages for business houses.. OR a srevice agent may sell the parts to you....Be aware that the inlet valves for hot and cold use are different on many models, and that you may void any warranty by installing yourself....Good luck....Nomess
Jun 23, 2010 | Fisher and Paykel Washing Machines
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
No cold rinse, only hot
Either the wires have come loose on the water valve or you have a defective water valve.Open the lid and look at the water valve. Are all wires connected?
If yes, replace the water valve.
Jun 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Noisy Water Fill
try closing your water valve a little, see of that reduces noise level and even off. you wanna see if its your plumbing or the machines valve
Feb 24, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
