Question about Miele CVA4070 Coffee Maker
Miele 4070 watersystem fault but the catch tray has no water so it's not overflowing. What might this be?
  • 128 Answers
It is leaking internally. When the drip tray is full, it tells you to empty the drip tray. when the machine has a problem and develops a leak, it locks up and displays watersystem fault. contact miele at 800 843 7231 and they can put you in contact with a service center in your area.
Posted on May 26, 2011
  • oohanow May 27, 2011
    thanks... appreciate the help.
Miele cva 4070 fault 81. What is this?
F81 is a steam heater fault - either the fuse or the steam heater itself are faulty, however if in fact you don't use the steam function - you can disable this in the setup menu
Oct 15, 2017 | Miele Coffee Makers & Espresso Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
The conditioner is still in the compartment at the end of the washing cycle
This is a common problem with many machines.
I suspect that it is the conditioner/softener tray which needs a thorough clean, paying particular attention to the sentences in BOLD OR the water feed into the softener tray is not working properly. If the latter, follow these instructions and then clean the jets where the softener water is supposed to enter before calling for service;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube
but on others the cover is part of the tray's plastic top. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 15, 2011 | Miele W4840 Front Load Washer
Our 1926A wont take the softener from tray
paying particular attention to the sentences in BOLD ;-0)
One of these should enable you remove it
(I am having to guess some of the following!)
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
John C
May 10, 2011 | Miele W1926A Front Load Washer
The machine never takes in the fabric conditioner. When the wash has finished the tray is always still full
Pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If water IS going into the tray I suspect that it is the conditioner/softener tray which needs a thorough clean, paying particular attention to the sentences in BOLD ;-0)
If these have assisted you please consider a 4 thumbs up for the rating.
John C
May 02, 2011 | Miele Washing Machines
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Miele coffee machine shows"watersystem fault"
Hello Wiesiek1,
The water system fault means that there is too much water on the bottom drip pan and it has tripped the sensor at the bottom of the machine. Usually removing the bottom grate where the cups sit and taking some paper towels and soaking up the water/spillage will fix this problem
Aug 29, 2009 | Miele CVA4070 Coffee Maker
Watersystem fault. Anchorage, Alaska
I've just had my machine fixed by a miele technician. Turns out the rubber beneath the water reservoir had worn out after 5 years. Because it was leaking, the machine was filling up with water. It protects itself by giving you the message. You can remove the reservoir, take a flexible tube/hose and drain the machine. It will probably fix the problem for a while. The Miele part number for the rubberseal is 05046331. Pretty cheap.
Jul 29, 2009 | Miele CVA615 Espresso Machine
Watersystem fault
This is a design flaw of the Miele CVA610 and CVA615. If the water reservoir is not properly installed, it will leak into the sump. The only solution is to have a turkey baster on hand for this invevitable situation. This has been confirmed to me by both a Miele technician and their technical support people.
Apr 18, 2008 | Miele CVA615 Espresso Machine
Watersystem fault
Thanks for the solution . I fixed my "Watersystem fault" . The wet switch in the unit is activated when water gets into the base of the machine to prevent water damage to the cabinetry .
Sep 08, 2007 | Miele CVA615 Espresso Machine
Miele CVA4070 Coffee Maker Logo
393 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
