Question about Sony Televison & Video
What the cause of dvd lense failure. - Sony Televison & Video
    Top Expert:
  • Sony Master
  • 74,185 Answers
Hello
The reason for the lens failure of DVD players cannot be predicted. There are so many causes. may be fo manucaturing defect, low quality laser diode fitted inside, sudden overvoltage in secondary supply rail of the player, long reading of unrecogonized disc inserterd and so on. The exact cause is still unknown. OK.
Posted on May 25, 2011
Dvd player tell me disk error
this could be aproblem with the lens which is unable to read the disk. this could be caused by accumulation of dirt on the disk sensor. open up the cover of the dvd player to access the lense and clean gently with a lense cleaner(a liquid purposely meant for cleaning the lense) apply this liquid on a soft piece of cloth and clean. close back the cover and power the dvd player it should now be able to load the disk
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
Disk won't load
First make power reset.
  • Switch off your DVD, remove power card from wall out-let. Then connect again and power-up.
  • Use CD/DVD lense cleaner to clean the lense.
  • Then try out.
Thanks
Iqbal
Apr 29, 2008 | Sony RDR-VX530 DVD Recorder/VCR
When ever I insert a dvd into my fisher dvd player it says no play
Try cleaning the lense of the laser. Small hairs get attracted and bend the light, causing missread. this clean has to happen manually, cleaner disks do not get down into the recessed lense area.
Jan 09, 2011 | Fisher DVD-SL30 DVD Player
Lg dp 781 is saying no cd when there is a cd in it and then sometimes it says disc error. we have played the cd's that are in it a million times before. help
Look closely, with lots if light and magnifying glass, at the pickup lense. Static attracts teeny tiny fibers and they bend the light and cause read errors. Also, smoking covers lense sometimes. Can be cleaned with rubbing alcohol and swab. I think that cd cleaning disks cannot actually clean as the lense is recessed.
Jan 02, 2011 | LG DP781 Portable DVD Player
HELP!
If the driver was the problem, the drive itself would not likely be seen at all. The message idicates that the disc can not be read. It is possible that the optics have failed, but normally there would be an indication of this prior to complete failure. Try cleaning the lens using a coton swab and alcohol. This should resolve the problem.
Update this if the problem continues.
Dan
Nov 09, 2009 | Computers & Internet
Dvd player keeps trying to read the disk and eventually comes up WRONG DISK
2 problems can cause the DVD to read wrong disk.
  1. LENSE IS DIRTY
  • buy a CD lense cleaner to clean the lense
  1. the disc is corrupted
Oct 05, 2009 | Coby Televison & Video
I have LG CD RW/DVD CD-ROM Combo Driver and my problem is that i can play CDs. When i insert DVD its showing blank or no DVD in the drive. How can I slove this?
It is your lense related issue.
You can clean your lense with disk cleaner disk purchase disk cleaner disk and put in dvd rom then play it.then it clean your lense.
But if still problem remains then your lense has issue.
So if your dvd rom in warrenty then take it to service center and replaced it .
It is is not in warrenty then you need to repair or replaced lense.
Jul 31, 2009 | Computers & Internet
My dv s5770 (yamaha)takes a long time to read the disc, if it does at all. sometimes it plays, other times it stops and skips to the next track/chapter. It goes from reading to dvd to info on the display...
The lenses of your dvd has a dust on it. You need to buy a cd cleaner , or you have to open the dvd and locate the lenses. Clean the lenses using cotton buds with alcohol.
Jul 23, 2009 | Yamaha DV-S5770 DVD Player
Dvd combo not detect dvd's
Your Lense has some issue.
You can clean your lense with disk cleaner disk.
Pur chase it from nearest shop it is called "Lense cleaner disk"
then put it into combo drive then play it then it clean your lense then check .
If still not access your dvd then if it is in warrenty go to service shop they replaced it.
And if it is not in warrenty then you should need to repair your lense or purchase new lense.
Thanks
Jul 22, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
DVD Disc Drive
So farit seems that the laser lense or the laser coil is bad. I found my lense chipped. One site indicated this is because of the use of "bad" DISCs that cause the laser diode to overload because of repeated attempts to read the bad disk. The coil and/or diod get hot and burn. I don't know how my lense got chipped!?
May 01, 2008 | Panasonic DMR-HS2 DVD Recorder
Televison & Video Logo
44 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
