Question about GE Refrigerators
NOT GETTNG COLD ENOUGH - GE Refrigerators
    Problem Solver:
  • 5 Answers
Probably low on refrigerant. This is not something you can fix yourself. Contact a licensed refrigeration mechanic
Posted on May 25, 2011
Magic chef wine cooler not gettng cold
at sears .com the schematic lists a "protector" part 265RFBYY
is this the overload?
also somewhere else I saw the temp stat was a problem, how would I rule this out? (Its expensive)
thanks
Jun 23, 2014 | Magic Chef MCWC45A Wine Cooler
2004 duucati multistrada kickstand too short? not strong enough, wrong angle?
This is usually because the rear suspension has been jacked up too far instead of getting a suspension jack up kit. Or a sloping car park.
Feb 11, 2013 | 2004 Ducati Multistrada 1000 DS
Frige is 4 years old and lst night it just quit keepingthings cold and the freezer is not gettng cold. Cleaned the coils below which were not that dirty. Need to know hat to try. Thans Ron
Hopefully you did make sure it is plugged in all the way or that a breaker or fuse has not blown. Sometimes we don't remember or think to check the obvious
Nov 28, 2010 | Maytag MSD2655HES Side by Side...
The refrigerator part is not staying cold. The freezer is wrking correctly and is freezing food. I vacummed all the dust out of the back but the refrigerator is not staying cold. It is running...
This can be a defrost problem or the fans may not be running. If the fans are not running then check the fans. I would need the model number to tell you if you have an electronic model or not because checking the fans is a lot different.
If it is a defrost problem the back wall of the freezer will be covered with ice.
This website has very good info on thses problems
http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 24, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
My kid turned the idle screw a few times now i cant start my bike it only backfires it started mint b4 this how do i reset my idle
hey, sounds like it was actualy the mixture scew that he turned, and if so your bike is probably just gettng way to much fuel or not enough, all you can do is turn it back untill it starts then adjust it untill it runs right, the idle shouldnt effect the running unless its too low but you can quickly determine this by starting with a bit of accelerator applied.
Feb 10, 2010 | 2002 Yamaha YZ 426 F
I'm gettng an error messae that says "Network processing timed out. Check the scanner and network status." What could be causing this? It's happening on all the devices with the scangear tool that has...
I'll need more specifications on your entire system configuration to be sure, but I'd say off the top of my head it is likely a RAM issue - as in not enough RAM to complete the operations you are requesting. Can you give specifics as to how much RAM your server has, how much RAM each of the clients have, etc.?
Dec 22, 2009 | Canon Office Equipment & Supplies
Refrigertor not gettng cold enough, and now freezer is doing the same. when we turn the number to 9 you can hear it go on - but still food is defrosting. Milk in frig not getting cold enough. Refrig is...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Reebok RB1 exercise bike is not increasing resistance and I wish to get inside to check to see if I can fix the problem but I am differculty in gettng the pedal lever off - can you help please?
Hello,you only have to take the peddles off. The right one comes of anti- clockwise, and the left one comes of clockwise. There is a large plastic ring on the cover at the place where the peddle shaft goes in. get a screwdriver into this and prise it of, this will allow enough for the cover to come of. Mines is the same not enough power to pull cable.
Sep 20, 2009 | Cycling
Prg3601p oven
I also have this problem Ihave replaced the igniter twice this helps some for a while  I AM GETTNG READY to order my third one. had dealer replace once they had no answer cut lighting time from fifteen to twenty minutes to maybe five
Jul 03, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
