Question about Conia DVD8500 DVD Player
I have a Conia CCD4501 cloths dryer which has stopped blowing hot air . It blows cold air only on the hot air cycle. The dryer still operates fine, but doesnt have hot cycle anymore. The cold cycle light is operating ok when switching between cold and hot , Have tested the elements which are fine they don't seem to be getting power. Where is the thermal fuse? Many Thanks
2 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: Conia CCD4501 cloths dryer not blowing hot air anymore
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Posted on Jan 13, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Conia air conditioner reverse cycle - not blowing cold air; checked setting its correct.. it seems to blow cool air, but house is not cold. It was working fine last summer, not sure of problem.
If you feel cool air near blower, you have to service your unit completely. Because it's giving cool but not removing heat from room due to coil and air filter blocking. Helpful?
Dec 30, 2010 | Heating & Cooling
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer blowing cold
Check the following to address this issue.
Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Please rate and have a great day:)
Jun 01, 2009 | Hoover Dryers
Jan 13, 2009 | Conia DVD8500 DVD Player
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Televison & Video Logo
46 people viewed this question
Top Conia Televison & Video Experts
Tom Chichester
Are you a Conia Televison and Video Expert? Answer questions, earn points and help others
