If you removed the sim card while the phone was powered on, it's possible that the card was damaged or the data was corrupted. You can try putting the sim card in an adapter and checking it with your computer. You may have to format the card again, then reinstall it in your phone, then power on your phone again.
that mean if your samsung is no signal or not read the simcard. try to use another simcard,change setting Phonebook to use Simcard Phonebook,and Open the Phonebook. if there you found the Contact on phonebook,that meaning if your samsung can reading the simcard. but if still Emergency Call,you need to bring it to phone service.
#1. is your phone open-line? if it's open-line, it should be able to read your simcard unless the problem lies in your simcard or the simcard connection is defective.
Hello
The Simcard might gone bad due to some reason, try this sim to other phone, if it not works then issue another sim to your service provider.
otherwise the contact at phone may gone bad, needs repair.
Good Luck
Alix
I am pretty sure when you dropped the camera the simcard reader was damaged and can no longer read your cards properly!
The camera can be fixed but it must be sent back to the manufactorer for repair! (this is a common problem when thses type of cameras are dropped or shaken!
I hope I was of help!
puk code is an eight digit code ,which you will get when you buy a simcard. if you have the packet of the simcard .you can find it in there.and also you will find the pincode.
OR you can contact your network operator for the same with your documents.
OR buy a new simcard.
when you use a new simcard the phone will not ask for PUK code.
