Bpl tv ksr 18a ic 8361 and circut diegram this kit parts no dliet
4 Suggested Answers
gopakumarg43
  • 75571 Answers
SOURCE: I neea BPL TV LWR 20 audio ic number LA4..7
Download the service manual to your TV
Posted on Jun 06, 2012
ercupa190
  • 12223 Answers
SOURCE: BPL SL640 Solor Circut Diagram
go to http://pdfservicemanual.com
God bless you
Posted on Sep 25, 2012
gopakumarg43
  • 75571 Answers
SOURCE: What is the remote code number for Bpl KSR 13SA1 MODEL TV
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Posted on Feb 25, 2016
Bpl prima colour tv.Eht no i replaced part ic 8361.dt.& dri tr. Eht.h out tr.all new part fix ic to . Smps volt 130.36.18.24.normally.but dt out no.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Televison & Video
Service mode bpl crt model no FYR 60YA2
Since BPL uses Sanyo kit, service mode entry method to Sanyo should work with it. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Service mode entry method to many brand TVs including BPL models are given.
Dec 04, 2013 | Hitachi C25-RF35S 25" TV
Bpl tv service mode
If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Service mode entry, adjust and exit procedure to many brand TVs are given in detail. Try the service mode procedure to any Sanyo model, as BPL TV uses Sanyo kit.
Nov 11, 2013 | Televison & Video
Bpl tv fcr 21
Check and replace its main system memory IC. It is faulty.
May 12, 2013 | Televison & Video
How to reset settings of BPL LWR 20 tv
I need LWR 20 audio ic number
May 13, 2012 | Televison & Video
I want bpl tv service code
I want bpl tv liv 20 service code
Aug 20, 2010 | Televison & Video
I have BPL tv model fzr21. it is unfortunatly
it is not possible to unlock without knowing the password,,,, u have to replace pre progammed memory ic to over come this problem , old ic contains the password must be removed..
Mar 12, 2010 | Televison & Video
The picture is only about three inches high in the middle part of screen and has a slight curve
vertical circuts or vert drive circut shady easy fix need more info on tv dlp proj plasma usually bad ic 1 or 2 18.00$apiec ver def ic look up ur part #go 2 nte electrnics.com buy part tip replace surrounding capacitors and output resistors good luck
Aug 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
