Question about Ovens
Will using an electric oven make the kitchen hot?
Naturally using any type of oven will make the kitchen hot, but it wont be nearly as drastic as an open flame such as a gas oven.
Posted on May 25, 2011
2 Suggested Answers
  • 197 Answers
SOURCE: My CDA fan oven will not get hot
Ok , classic example of a fan oven element blowing, take the cover off inside the cooker held on by 4 screws so you can see the round element, you should be able to see where its blown a big hole.
replace element
( make the cooker is turned off of course)
Posted on Sep 21, 2009
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
I have a stoves double oven the fan oven heats up but not hot enough could it be the stat and if so how do i replace it.
It could be the stat. First check that the sender unit located at the top rear of the oven above the fan cover is bright and clean and not covered with dirt and grease. Use a paint on oven cleaner to clean it in situ as it is quite easily damaged. Lakeland do one. If that doesn't work, then the whole oven unit will have to come out of the kitchen carcass and the the top and rear oven covers removed for access. Try espares for the part. If you want to check the oven temperature before you start, Lakeland do an oven temperature thermometer for about £5 which I have found is accurate.
Jan 03, 2011 | Stoves 720EF Electric Double Oven
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
replace element
Sep 18, 2009 | Ovens
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
May 24, 2009 | Jenn-Air Electric Double Oven
Neff B1721 oven
good day,
hope this link below will solve your problem.
kitchen appliances
Oct 20, 2007 | Neff B1721 Compact single Circotherm oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
