Question about Shimano Dura Ace 7800 10 Sp
How to replace a gear cable on a 7800 shifter
    Brigadier General:
  • 8,546 Answers
2 Suggested Answers
  • 632 Answers
SOURCE: can 7800 shifter use with 7900 front derailuer
Any derailluer can be used for the front and the rear should match how many gears it will choose.
Posted on Apr 30, 2010
Tips on installing the 7 speed revoshift sis shifter
Obviously, you must remove old shifter. With old cable removed, make sure you derailleur is on the smallest gear (7). String cable through cable housing, checking to see if there is any tight spots. The tight spots are places in the housing where the cable doesn't move freely. These are rust or bad spots in the housing, If you have a bit of problem, put some oil in the housing work it back and forth. If you have several problems consider replacing housing.
Now back to the installation, you gave the cable through the housing, set shifter on 7 or highest gear. Simply tighten cable at the derailleur. Tighten the derauiluer cable bolt. Check your work by running through the gears, if shifter doesn't shift thru all gears, check for slack in the cable. If slack, redo the operation again. If you continue to have problem, consider your local bike shop for assistance.
Nov 02, 2014 | Cycling
My 89 vw cabriolet automatic wont go into gear after towing it replacing filters and shifter cable
My first thought is bent shifter forks or linkage is off. Start with the linkage as it is easier. Shifter forks are internal tranny components.
Apr 03, 2014 | 1989 Volkswagen Cabriolet
Gears are in the wrong order after manual shifter cables replacement
Did you make sure the gear stick was in the same position when you fixed the new parts and parts are tight enough.
Or take cover off gear stick in car where it goes into the selector and reset the gears from there.
Jan 14, 2014 | Toyota Tercel Cars & Trucks
Dura ace brifters very sticky
You can squirt them with a spray lubricant (bicycle lubricant) to free them up if it is just a dirt issue, you need to pull the brake lever to expose the internal gearing mechanism, don't take anything apart.
If your shifter part is sticky, this usually clears things up. If it does not make trace through the derailleur cable and make sure it's not the cable hanging up instead of your shifter. Replace the cable and housing as necessary.
If its the brake lever, smae check of the cable system but also check the brake itself. The lever will feel sticky when there is a snag in the cable or if the brake is no longer returning with the same spring tension.
After that you can have them rebuilt or replaced. Depends on which model you have 8, 9, 10 (7800, 7900) as too the exact recommendation.
Dec 30, 2010 | Shimano Cycling
Hi guys, my pride & joy JD7800.. WAS PARKED NOTHING WRONG.. WHEN STARTED DOESN'T GO INTO GEAR AT ALL.. SHIFTER WORKS BUT NO GEARS AT ALL, DASH DISPLAYS FAULT d1A, Please please help no money for...
Take the fuse out of #115 that will take you out of diagnostic mode. When you put it in reverse and it doesn't move then see what code comes up on the dash and follow up with me.
Dec 02, 2010 | John Deere 7800 Modern Farm Tractor Kit -...
Can 7800 shifter use with 7900 front derailuer
Apr 30, 2010 | Shimano Dura Ace Front Derailleur Fd 7800
Gear shifter just slide thru all gears without
If the vehicle fails to engage in any gear and feels loose the shifter cable is broke.This cable isn't easy to replace, you may want to have a mechanic replace it if your not familiar with it.
Jan 30, 2010 | 2000 Chevrolet Lumina
Require assembly schematic for shimano dura ace shifter . left shifter lever failed, will not activate the front derailler, disassembled, found nothing broken, require advice regarding proper reassembly...
log onto Shimano.com, it is probably the limit screws (the two screws that limit travel) or you have a faulty ratchet in the lever, try the shimano website anyway they have great tutorial and manual support
Nov 14, 2009 | Shimano Dura Ace Front Derailleur Fd 7800
Shimano Dura Ace 7800 10 Sp Logo
1,090 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
