Question about Ingersoll Rand Ingersollrand Dual Action Air Sander - 6" Dia, 4 CFM 10,000 Rpm, Model - 311A
I have a Ingersoll-Rand Model 310 air sander rated speed 12000 RPM I have the original parts list and I need some Orings who would I get the parts from it was manufactured in 1985
  • 98 Answers
SOURCE: i need to download a
call I.R and they will send you a manual for a small charge.
Posted on Jul 21, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
  • 17 Answers
SOURCE: need compressor parts for type 30 Ingersoll-Rand Compressor
contact ingersoll rand they are helpful http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
  • 1388 Answers
SOURCE: I have an Ingersoll Rand Type 30 air compressor.
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Posted on Sep 25, 2010
How to assemble an ingersoll rand sander 315
Gear timming in line sander
The above link may help as the unit is similar to the Central Pneumatic Straight Line Sander
Mar 02, 2015 | Ingersoll Rand Ingersoll-Rand IR 315 Heavy...
SANDER RPM IS LOW , EVEN AFTER MAX AIR SUPPLY
Turn dial on side,or on bottom of sander should change rpm.
Sep 19, 2012 | Ingersoll Rand 313A IR-313A 7"Dia 5000RPM...
Diagram of parts
you can download ingersoll rand tool manuals and parts lists from
www.irtechpubs.com
Jan 22, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
How do i change the sanding pad Ingersoll Rand Ingersollrand Dual Action Air Sander - 6
It simply unscrews. The pad is held on by a small bolt length attached to the pad. Unscrew it.
Jan 15, 2012 | Ingersoll Rand Ingersollrand Dual Action...
Looking for parts list. missing strart capasitors etc.a manual or schedule can help me out.need to buy some parts ingersoll rand dd2t2
Hi johnny camer.
Sorry I could not find a parts list for your compressor model
But I found the ingersoll rand contact number, you can call them and talk to them on the net and get the right parts and manual you need.
Please take time to rate me
http://www.ingersollrandproducts.com/IS/Category.aspx-am_en-31052
Aug 31, 2011 | Ingersoll Rand DD2T2 T Win Stack Single...
What the maximum working torque for a Ingersoll Rand 1/2 2705P1?
Ingersoll Rand 2705P1 1/2 inch 40-200 ft lb Industrial Duty Impact Wrench
Max Torque 400 Ft-Lb
Pneumatic Impact Wrench, Industrial Duty
Pistol Grip Style
Standard Anvil
Square Drive Size 1/2 In
Torque Range 40-200 Ft-Lb
Average CFM @ 15 Second Run Time 4.2
CFM @ Full Load 23
Max Bolt Capacity 5/8 In
Free Speed 8500 RPM
Pin Retainer Type
Required Pressure 90 PSI
Air Inlet 1/4 In
Min Hose 3/8 In
Overall Length 6 3/4 In
Weight 2.55 Lbs
Country of Origin: USA
CR 4Z942
Mar 28, 2011 | Ingersoll Rand Air Tools & Compressors
How do i use this thing
Yes it should screw on and the sanding pads should either be sticky or velcro
Oct 02, 2008 | Ingersoll Rand Ingersollrand Dual Action...
Ingersoll Rand Ingersollrand Dual Action Air Sander - 6" Dia, 4 CFM 10,000 Rpm, Model - 311A Logo
330 people viewed this question
Top Ingersoll Tools & Hardware - Others Experts
Mike
Eddie Tucker
Level 1 Expert
Lawrence Oravetz
Are you an Ingersoll Tool and Hardware - Other Expert? Answer questions, earn points and help others
