Question about Canon PowerShot SD850 IS Digital Camera
The blue light is on in the back but the camera will not come on
    Sergeant:
    Champion:
  • 214 Answers
Hi would you tell me more about the blue light like? Does "the camera will not come on" mean on the picture that you took? If I am understanding right, then you have sort of defective image sensor defective or some light are leaking through. However, functionally it won't have problem. Thanks and best regard!
Posted on May 25, 2011
I bought a Ouku 7" screen DVD Navi unit for my 2009 Honda Civic. There are 4 loose wires on the harness labeled as follows:
Orange goes to the switch on the emergency brake. This allows the DVD player to play movies with the brake on ( liability issue...people sued and bankrupted a manufacturer because they watched tv while driving and some people got killed) should be the light green wire at the switch on the ebrake handle.
Blue is used on a vehicle with factory analog steering wheel controls
pink is connected to the back up lights and activates the backup camera feature if you have a back up camera
blue w/white stripe...best guess has to do with infra red remote ...possible allows an ir eye to be installed.
I would suggest go ogling the model number for a wiring diagram or owners manual if you don't have one.
Nov 01, 2016 | Honda Cars & Trucks
Flashing blue light on back of camera and it won't turn on
The little blue light on the bottom of the back side of the camera is the memory access light. As long as the light is on, or is flickering, you should not open the battery cover or the memory cover. You definitely should not remove the battery or the memory card as well.
If the light is flashing, it can indicate the camera has problems accessing the memory.
If it continues, you should switch of the camera and remove the card. Then check in an external memory card reader if all pictures are still there. Get all pictures from the card and backup to a computer. Then do a format depending on the size of the card, FAT12 FAT16 or FAT32. Replace the card and let the camera format the card again.
If you do have another memory card, first save all pictures to the computer, only then put the card in your camera to check if that card works better in your camera.
If you need to recover pictures from your card, because the computer can't read them, there are enough recover programmes around on the net. Lots are free.
Jan 30, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Is my camera charging when plugged in with usb cord it has a blue screen and says MSDC?
The charge light on the back of the camera will light red while charging and go out when fully charged. Your camera should have also come with a separate battery charger if the above method doesn't work.
Jan 09, 2010 | Vivitar ViviCam 8025 Digital Camera
EOS 30D - blue print light then dead
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom right of your computer screen or did you just yank out the cord?
Jan 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Blue stripe and constant flash even in bright light conditions
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 29, 2009 | Canon PowerShot A590 IS Digital Camera
Pictures have a blue colour
You have not said w2hether these are daylight pics or pics taken inside under halogen lights. The later requires a blue filter.
Daylight pics that show blue are set to the wrong Kelvins in your menu. Set the camera back to factory settings and make a note of the Kelvins ( temperature scale) that is the standard setting.. You can manipulate the color of the pics taken in certain light by moving the scale upward to warm the pic in overcast situations or down in bright light to remove red cast that some light or lights ( bulbs) tend tp create in pics.
Pleasse rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Olympus EVOLT E-500 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
My veo camera do not power up
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 27, 2008 | Veo Wireless Observer Network Camera
My sanyo vpc e760 don't work
This has happened to me as well. Mine, however, actually worked for a day or two and now it's giving me the blue flashing light. Man, this sucks, it was a b-day present!
Dec 22, 2007 | Kodak V803 Digital Camera
Black pictures with blue lines running horrizontally through them
If you are able to see the picture in the LCD in black color and if there are no damages to the LCD -the LCD is fine. There is a back light panel attached behind the LCD which may be defective.Check for the loose connections. If you need spare parts contact me.
Nov 26, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon PowerShot SD850 IS Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
