Question about Microwave Ovens
I have a qasair rangehood (uv-1200-2) with 2 lights. The lights have not worked for a year or so. I have now replaced them (following http://www.qasair.com.au/images/installation_inst/QAIInstr_Lamp.pdf ) but they are still not working. I have turned the power off to the kitchen and then on again, but they still dont work. What should I do next?
  • 1 more comment
  • Home-body May 25, 2011
    Mmmm - not particularly helpful.
    (a) All I can see are the wires that come through the light holes (once the lights are removed according to the instructions referred to). This consists of wires and a piece at the end into which the two prongs of the light are inserted.
    (b) The statement for UVs ( athttp://www.qasair.com.au/images/installa... ) refers to 'low voltage halogen lights'. Are you sure that you are looking at the same model?
    Can you please confirm that you are still looking at this?
    Re your question above, both lights are 12V, so it appears to be a transformer issue, and I cant get to the transformer (i.e. no obvious screws etc and the unit is installed in a chimney). Given this, I would have to dismantle part of the unit (which is installed in a chimney) to get to anything other than the wires, therefore I have given in and called the technician. However thanks for your help - you have clarified that there are no fuses, or other things that are within my competence to do before giving in.
  • 1,606 Answers
First, turn off power to the rangehood. Check the contact resistance of the light switch(es) with an ohmmeter. It should be less than 0.1 Ohms. If you get a substantially higher resistance in the on position, the switch contact is burned out. Also, inspect the wiring harness connector and the connections to the light fixtures. If they show signs of overheating, the connection resistance is too high. You can try polishing the connector contacts to remove oxidation. I use a pencil eraser for mild cases and a non-metallic dry scouring pad (3M Scotch-Brite) for more severely tarnished contacts. In the worst case it will be necessary to replace the terminals or connector.
According to the drawing for this series on the Qasair website, the unit uses fluorescent lamps rather than the halogen lamps referred to in the lamp installation instructions. If this is true, it is likely the ballast has failed (if the lamps have separate switches, they probably have separate ballasts also). If the original ballast model is no longer available, make sure the replacement has at least as high a maximum temperature rating as the original. This is especially critical for electronic ballasts. You can extend the life of the new ballasts by making sure the fans are running before turning on the lights - this should reduce the ambient operating temperature inside the hood.
Posted on May 25, 2011
  • Paul Bade May 25, 2011
    This is the drawing I mentioned. I had planned to include the link in the original message, but lost it in an interruption. Sorry about that.
    If you remove the fan filters, can you see any other access to the wiring such as panels with screws in them? You may have to peer through the fan blades or temporarily remove the fans.
    If the lamps are low-voltage, there is a transformer or power supply to step down the mains voltage. In that case, the same considerations I mentioned for a ballast apply, except that the switches could be on the low voltage side and the lamps would share the supply. Your description of the socket seems to indicate this is the case. Can you verify the voltage of the lamp (it should be marked on the lamp if it is not a fluorescent type)?
    If you find a simple transformer, you can (again, with power to the hood turned off) check it with an ohmmeter. You can check the secondary side by removing the lamps and measuring resistance through the socket contacts with the switch turned on. It can read in the tens of ohms, but it should not be open. To check the primary, you will have to get access to the internal wiring and make sure all the fans are off so they don't interfere with the reading. The primary resistance could be in the tens or even low hundreds of ohms, but should not be open.
    I note that the letter F has been added to the model number in the drawing. I surmise you have a previous version and the newer version uses Fluorescent lamps. The layout is probably quite similar.
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
Parex beta 90 ss rangehood stopped working Lights on switches work but not the fans or lights
Unfortunately didnt do anything about this for years. Managed to take off the white box behind the front panel swithes. Opened this up and "hey presto" the circuit board is faulty. Wouldnt it be nice if De Longhi sent out another one free of charge as this is obviously faulty, looking at some of the same complaints that have been posted. Imagine all the people that dont use computer or internet. I soldered wire between the points and it worked straight away.
Jun 10, 2011 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
I turned on the light of our wp rangehood and it popped; now i have no power to the microwave. i checked/reset circuit breaker, replaced lightbulb but i got nothing. it is 7 years old. how can i fix it?
First you need to replace any blown fuses. Consult the mini-manual / technical sheet hidden behind the grille or control panel.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Concerning the failed lights, we see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Feb 15, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Where can i get the Dishlex ranghood filters that more than 20 years old ?
The following Australian site carries Dishlex parts. You will need to know the model number of your rangehood or the size of the filter. If you know the model number simply do a more specific search to narrow your choices.
http://spares.alliedappliance.com.au/search.php?match=&keyword_list=Dishlex+rangehood+filter
Feb 15, 2011 | Microwave Ovens
Kenmore 63682300 Bulb blew now lights won't turn off
See if I get what you are saying.Sounds like the light switch is bad.That would be the first thing I would check.
Mar 14, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Replacing inverter board for my sharp R-2130JS microwave
I do not know how to specifically replace the "inverter board" in this model. On most microwaves I've repaired, though, the hardest part is getting them dismounted from the wall if they are rangehood models. I suspect that the inverter board is held onto the chassis with two phillips screws, and all the connections thereto are modular and therefore easily disconnectable and swapped out. The great majority of times, manuafactureres do NOT put multiple connectors of the same pin count and oriention on a circuit board. Give it a go.
Feb 27, 2009 | Sharp R-2130JS Stainless Steel 1200 Watts...
Microwave Ovens Logo
1,406 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
