Question about Canon PowerShot A1100 IS Digital Camera
Flash will not fire - Canon PowerShot A1100 IS Digital Camera
    Sergeant:
    Champion:
  • 214 Answers
Hi your camera has two possible problem cause. first is brown fuse. two is flash pcb unit defective. your local repair shop would charge around $35 to 85 depend on what they really want to charge. Thanks and best regard!
Posted on May 25, 2011
My quantum flash is misfiring...fire a few shots, then misfire again.
I can repair it for you or try this first.
Turn power on with no camera connection.
Does it fire by itself?
PC Sync on camera, does flash fires by itself?
Dec 14, 2012 | Quantum Qflash® 5d TTL Flash
I have a HP Photo Smart R707 with a fully charged new battery and the flash won't work. Keep getting charging flash. Any help on this?
The flash mode has to be set.
There are 5 flash modes:
  • auto - flash fires when needed
  • red-eye reduction - flash fires when needed, but there's a pre-flash to minimize red-eye
  • flash on - flash always fires
  • flash off - flash never fires
  • night - flash fires if necessary (and uses red-eye reduction) to illuminate foreground objects, but shutter stays open to record the background by ambient illumination
http://www.bobatkins.com/photography/digital/hp707.html
Aug 11, 2010 | HP Photosmart R707 Digital Camera
Flash will not fire. Light indacts if fired, but no flash. Good contact and fresh batteries.
Hi Tam,
Try this:
Flash on
Flash ready.
Short out center pin to outside contact..this will fire the flash.
atdlee@netzero.com
Jan 12, 2010 | Sigma EF-500 DG ST (EO-ETTL II Canon) TTL...
QFlash does not fire
You have a defective PC Cable.
Try this:
Turn on flash and wait until ready.
With PC cable connected to flash only.
Short out center pin to outside of PC Cable, this should fire the flash.
a.l9609@gmail.com
Jun 11, 2009 | Quantum Q Flash T5dR Digital Flash Head...
The flash will not work on my Samsung S860 Digital Camera. It used to work and now it doesn't... I tried to go through the menu to fix it and it seems to say it is on? But, when you take a picture it does...
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Mar 08, 2009 | Samsung S860 Digital Camera
AC Slave Flash - How make it works
A slave flash unit is a flash that has a sensor that fires the flash when it senses the burst of flash from the camera's built-in flash unit. Since many digital cameras fire the flash twice for each picture (the first is to set white balance and perhaps focus), these units are designed so they fire when the camera's second flash goes off.
To use it with your D60, just use your built in flash to fire off the slave flash...
Mar 03, 2009 | Morris AC Slave II Flash
Continous firing flash
You have a bad cpu chip in this flash . You need to send it ijn the the manufacture at NIkon .
BERRIE SMITH CAMERA REPAIR
770-312-0719 / bbmw@bellsouth.net
Oct 27, 2008 | Nikon Speedlight SB-600 TTL Flash
Flash Not firing
Hi , try to flash in dark area and set camera flash on set in all option.if does not fire the flash the flash bulb are busted either the the igniter switch inside was broken.
May 07, 2008 | Nikon Coolpix L11 Digital Camera
Flash won't fire
If it clicks when the flash is already open, it seems there would be a problem with the flash open sensor. The camera thinks the flash is closed, so it tries to open it again and it refuses to fire, because firing in the closed position would blow the bulb.
Here's a <a href='http://photo.net/bboard/uploaded-file?bboard_upload_id=42254384'>photo of the sensor in a D70</a>. The D40 flash is a bit different, but if you open it (just unscrew the two little screws in front) you'll recognize the sensor clips. Open and close the flash and see if the make contact when open.
(And DON'T fire the flash when open, or at the very least don't touch anything in there when firing or you'll get zapped.
Apr 02, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A1100 IS Digital Camera Logo
52 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
