Question about Samsung MW1030WA Microwave Oven
GE Spacemaker XL1800
I have a GE Spacemaker XL1800 that I cleaned the outside area vent and may have inadvertently gotten water in the vent and now the touch panel is not working any ideas/
  • Samsung Master
  • 9,086 Answers
Direct spraying of cleaners and steam from the cooktop can damage the controls.
Always spray any cleaner (non-ammonia only) on a soft cloth (not a paper towel which can scratch) and gently wipe the unit.
Always use the vent fan when cooking on the stove top to keep steam and grease out.
Otherwise, the cleaner or grease can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
Then you can use a hair dryer (not too close) to help dry any moisture you see.
If it still isn't responding after that and a day's wait or so, it will probably need a new keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
GE Spacemaker XL1800 vent fan doesn't pull air from beneath
On the exhaust system (top of unit) there is a small metal 'damper' that is most likely stuck shut. If that is all clear then you have a problem in the duct work of the home.
Feb 23, 2014 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 microwave suddenly didn't work. All buttons on the front panel except "Clock" don't work. Open the machine, shorten the thermostat, the vent fan runs automatically....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung MW1030WA Microwave Oven Logo
91 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
