Cant access internet i even tried thru a wireless router and the error was internet limited. It also saying that need to fix driver 802.11 bg WLAN
    Scholar:
  • 134 Answers
WHAT TYPE FOR YOUR WIFI ROUTER?B/G/N?
WHERE YOUR ROUTER? HOME?COMPANY?
IT IS INTERNET LIMITED OR LIMITED USER?
Posted on May 25, 2011
I need to secure my home wirless network
1) Secure your wireless router or access point administration interface
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
2) Don't broadcast your SSID
Most WLAN access points and routers automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
3)Enable WPA encryption instead of WEP
802.11's WEP (Wired Equivalency Privacy) encryption has well-known weaknesses that make it relatively easy for a determined user with the right equipment to crack the encryption and access the wireless network. A better way to protect your WLAN is with WPA (Wi-Fi Protected Access). WPA provides much better protection and is also easier to use, since your password characters aren't limited to 0-9 and A-F as they are with WEP. WPA support is built into Windows XP (with the latest Service Pack) and virtually all modern wireless hardware and operating systems. A more recent version, WPA2, is found in newer hardware and provides even stronger encryption, but you'll probably need to download an XP patch in order to use it.
4) Reduce your WL-AN transmitter power
You won't find this feature on all wireless routers and access points, but some allow you lower the power of your WL-AN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WL-AN.
5) Disable remote administration
Most WL AN routers have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the router. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off
Thanks
Have great day
Sep 04, 2010 | Computers & Internet
Tip
How to secure your wireless router
Most WLAN hardware has gotten easy enough to set up that many users simply plug it in and start using the network without giving much thought to security. Nevertheless, taking a few extra minutes to configure the security features of your linksys router wireless or access point is time well spent. Here are some of the things you can do to protect your wireless network:
1) Secure your linksys router wireless or access point administration interface linksys router wireless have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the linksys router wireless or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
2) Don't broadcast your SSIDlinksys router wireless automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
3)Enable WPA encryption instead of WEP802.11's WEP (Wired Equivalency Privacy) encryption has well-known weaknesses that make it relatively easy for a determined user with the right equipment to crack the encryption and access the wireless network. A better way to protect your WLAN is with WPA (Wi-Fi Protected Access). WPA provides much better protection and is also easier to use, since your password characters aren't limited to 0-9 and A-F as they are with WEP. WPA support is built into Windows XP (with the latest Service Pack) and virtually all modern wireless hardware and operating systems. A more recent version, WPA2, is found in newer hardware and provides even stronger encryption, but you'll probably need to download an XP patch in order to use it.
4) Remember that WEP is better than nothing If you find that some of your wireless devices only support WEP encryption (this is often the case with non-PC devices like media players, PDAs, and DVRs), avoid the temptation to skip encryption entirely because in spite of it's flaws, using WEP is still far superior to having no encryption at all. If you do use WEP, don't use an encryption key that's easy to guess like a string of the same or consecutive numbers. Also, although it can be a pain, WEP users should change encryption keys often-- preferably every week. See this page if you need help getting WEP to work.
5) Use MAC filtering for access control Unlike IP addresses, MAC addresses are unique to specific network adapters, so by turning on MAC filtering you can limit network access to only your systems (or those you know about). In order to use MAC filtering you need to find (and enter into the linksys router wireless or AP) the 12-character MAC address of every system that will connect to the network, so it can be inconvenient to set up, especially if you have a lot of wireless clients or if your clients change a lot. MAC addresses can be "spoofed" (imitated) by a knowledgable person, so while it's not a guarantee of security, it does add another hurdle for potential intruders to jump.
6) Reduce your WLAN transmitter powerYou won't find this feature on all wireless linksys router wireless and access points, but some allow you lower the power of your WLAN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WLAN.
7) Disable remote administrationlinksys router wireless have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the linksys router wireless. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off. (It's usually turned off by default, but it's always a good idea to check.)
source: http://www.linksysrouterwireless.com/article/Securing-your-wireless-network.php
on May 28, 2010 | Linksys Wireless-G Broadband Router
Need help with wlan code
Security Code is configued in Wireless Router itself.
Please open your Wireless router Admin Panel in Internet Explorer. Please follow this steps.
1. Open Internet Explorer and type : http://192.168.x.x and press enter (x is router IP. Generally its 1.1 or 0.1)
2. Go to Wireless Security Tab and look there for Security code.
Now type that Security code in your Ps3 .
You find all details regarding to access router in internet explorer from Product Manual. (you can download product manual from Manufacturer site)
Mar 22, 2010 | Belkin (F5D7230-4) Router (587009)
I have a laptop running 802,11 g/b and vista and I Cant connect to linksys wag160n wireless router(802,11 n). laptop sometimes recognises network but when I try to connect it wont. could you help ?
Hi, You cannot connect across wireless protocols. In other words to connect to 802.11 n you need an "n" adapter.
Now, the router should be backward compatible & provide wireless g/b but you may find that when you search for networks it will be listed as a seperate network name (from the same router)
Try searching for this other network. Your router documentation should advise you of its default name & any set up process
Dec 23, 2009 | Acer Computers & Internet
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Wireless network connection problem
Ok with a peripheral on USB or on PC card bay you can try to connect to a Wireless lan:
Please check this tip on the subject
To connect to an existing WLAN you must be sure your wireless card is working: I assume you installed all the related sw coming with the wlan card.
Using the card installed driver check card is enabled and running (in Control Panel/Network connection should be visible and enabled)
Then you can connect to an open Wi-Fi HOTSPOT or to your WLAN you configure with a router connected to your internet modem.
  1. To connect to an existing HOTSPOT: find a location where you know a wi-fi access point (HOTSPOT) is active: Internet cafe,, library, airport,, station, hotel etc.your card should be able to find the existing network when you select "show existing network" in wlan driver. Connect if network is "unsecure" (= no password or key is required) or ask for password if you can get it for a fee (hotel)
  2. To connect to your home or office WLAN be sure to use a router (or access point) with same standard of your card (802-11G or B or A or N) with same security protocol (WEP or WPA) and configure your router Internet access BEFORE wireless access. Connect your PC to your router using a LAN cable and be sure you can browse through the router.(contact your ISP for router specs if you need it: PPOA/E and other). Follow the tip and your router doc for settings
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Netgear WG602 wireless router, Connection Local only !
What I think is you unplgged them at the wrong times.
Do this:
(in this order)
  1. Turn off the router.
  2. Turn off the modem.
  3. take out all the Ethernet cords from the router, EXCEPT the one coming from the modem
  4. Now turn the modem on.
  5. Wait for the lights, then wait about another minute for it to settle.
  6. Turn on the router, make sure the Internet,Lan,Wlan,etc lights are on and functional if it doesn't display a light let me know.
  7. Now depending on what your wireless network (SSID) is called try to connect to it. Go to Start>Network>Click Network And Sharing Center at the top>on the left select Manage Wireless Networks>now click add, if your network is already on the list shown select it and click remove otherwise click "Add" click "add network in reange of this computer" select your network name and click connect.
Now tell me the errors, like if it says connection limited,etc...
Thanks,
Cam
Oct 18, 2007 | NetGear WG602 802.11g/b Wireless Access...
Computers & Internet Logo
David Payne
David Payne
