Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer cartridges what is the right size printer cartridges for the hp officejet 6210 all-in-one and why does it always tell me to remove and check color cartridge. I do this, and there appears to be ink left in the tank, but leaking. Is there a way to clean the spilled ink from inside the machine and should I try to clean the contacts on the cartridge itself? I am currently using hp97 refilled for color and hp94 for black. I am getting conflicting numbers for cartridges hp 95? is that for color also?
  • 876 Answers
Dispose of the leaky cartridge. Clean the contacts in the machine with a little rubing alcohol and a q tip (don't soak it-just moistened it a bit) Make sure the Printer is turned off while you are doing this. While you are doing this I will look up your cartridges and what they are for. I suspect that you have a color cartridge/a regular black cartridge/ and a black printing only cartride but I will check. Don't ever use a leaking cartridge they can damage your printer.
Posted on Aug 16, 2008
HP officejet 6210 all in one...message is"remove
Hi Jim,
When you install a new cartridge, be sure not to touch the contacts, and make sure the contacts on the cartridge align with the contacts on the printer, and all packing tape has been removed. If the contacts on the printter are coated with dry ink, you should clean them with a cotton swab and distilled water. Dampen the swab and wipe off the dry ink on the contacts and let it dryt. Also, run the cartridge alignment on the new cartridge.
I hope this helps. Let me know if you need further assistance.
Randy
Feb 09, 2012 | HP OfficeJet 6210 All-In-One InkJet...
Carriage jam print cartridge stalled HP 6210 Officejet. It started all of a sudden and I can't fix it
Press "ON" till green lite appears. The display will indicate "Initializing..." and then lift upper half of the printer to access cartridges. Cartridges should move all the way to the right. If they don't, inspect the carriage belt for any obstructions.
Nov 06, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have an HP Officejet 6210 All-in-one. The
1st check the ink spare is for your printer, then take the protective cover out (ink cartridge), check for any stucked/broken plastics. if all is ok, send printer to repair to check.
Dec 28, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printer cartridge
Try celaning the cartridge contacts as shown here (for a different cartrdige, but same principle). If this does not fix the problem you will need to contact your dealer of the edible ink cartridges for warranty replacement.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Sep 19, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Mar 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Printer won't work
    Replace them with Genuine HP cartridges
    Feb 24, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Remove and check color cartridge
    the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
    Dec 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
    HP officejet 6210 all-in one
    ok i found a way to help you find those 94's 97's printer cartridges
    http://computers.pricegrabber.com/ink-toner/m/3768822/
    this link is for the hp 94 cartridge
    http://computers.pricegrabber.com/ink-toner/m/3768824/search=hp%2097/st=product/sv=image/
    this link is for hp 97 cartridge
    from the uk i hope this helped you find the right cartridges
    338-334 is there new numbers if there not put in right the cartridges will have error to them kinda snap in with little force
    May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Officejet 6210 all in one
    Remove and check color cartridge message
    Nov 15, 2007 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    158 people viewed this question
    Ben Johnson
