Whirlpool front load washer GHW9100LW
Error code F06 (drive motor tach error) what do I do?
  • jackieschubb Jan 27, 2009
    I have a Maytag Epic washer and it is showing the F06 code also.  Is this the same problem?  Repair man is coming Thursday.
    Brigadier General:
  • 6,966 Answers
Appreciate the "Ask Me".
My compliments that you have determined that error code F06 indicates drive motor tach error. This relates to the controller board not sensing that the motor is spinning. This could be attributed to three (3) possibilities:
  • motor is not really turning/stuck, a replacement is required;
  • motor is turning but the sensor attached to it is defective and therefore not sending signals to the controller board. Pls check the terminals/connectors/wirings; and/or
  • the controller board input circuitry is defective. It does not register any input from the motor's RPM sensor. This could be a diode, resistor or logic IC. This would be component level repair requiring familiarity with electronic circuitry and components, use of a DVM and a soldering iron. It wold be easier to replace the entire controller board..
In some instances, it could just be the motor's capacitor that is defective. The capacitor provides the initial kick for the motor to start running. Failure on the capacitor will not kick start hence motor will not start hence RPM sensor says to controller board motor not running.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 16, 2008
Whirlpool Washer GHW9100LW F02 code- what does that mean?
Posted on Oct 28, 2009
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
Whirlpool duet front load washer, F06 error
FROM WHAT I CAN FIND OUT YOU HAVE A DRIVE MOTOR PROBLEM,
IF YOU TYPE IN YOUR SEARCH BOX (WHIRLPOOL FAULT CODE F06) there are several several sites that tell you how to fix it
Nov 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My maytag washer model MFW9600SQ0 has an F06 error code. It was previously vibrating during the spin cycle then the error code showed up. I took the back off and found one of the springs that the drum...
The F06 is a drive motor tachometer failure which means the motor control is not able to see the motor is running. This can be a difficult problem to pin down, but there are some things you can do yourself if you like. Check the connections between the motor control and motor. Also check connections on the central control are all tight. Push on all of the connections and see if there is any improvement. The images below will help with access on some Maytag front load washers.
Image 1
Image 2
Sep 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet does not wash it keeps coming a code F06, what could it be
F06 error code is Drive Tach Motor Error.
The cause of this is the motor control (MCU) not communicating with the control board. Try unplugging the unit for 30 seconds and if this does not solve the problem replace the MCU. This is located behind the panel under the door screwed to the floor of the unit near the motor.
Click HERE to order the replacement MCU
Hope helps.
Aug 15, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F06 error with a ghw9150pw4 model whirlpool front loader washer
HI There
Here what you need on error codes.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Hope this helps let me know. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f06
F06 is a Drive Motor Tachometer Error (Unable to Detect Motor Speed).
Disconnect mains power and unplug unit. Check the wire harness connections between drive motor and Motor Control Unit (MCU), and then between MCU and the Central Control Unit (CCU).
Reconnect mains power and switch the unit on. Check the MCU by looking for operation of the drive motor and check drive motor for cyclic powered rotation. Replace any failed component.
Note: If this failure occurs during high speed spin, the door will be unlocked after three minutes
Oct 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Washing Machines Logo
635 people viewed this question
Top Washing Machines Experts
